02-03-2009, 09:44 PM | #1 |
Rock Stacker Join Date: Jan 2009 Location: Rio Rancho NM
| Bent links
So I put bent links on my ax10 rtr and now the lower control arms are binding with the springs lower cups.. Did I miss something during the upgrade or is there a trick to fix this problem?
02-03-2009, 09:50 PM | #2 |
Quarry Creeper Join Date: Sep 2008 Location: !! MOAB !!
Move the links from inside the axle mount to the outside closer to the pinion. You will need some 25mm screws to do this but it will clear up the binding problem.
02-03-2009, 09:51 PM | #3 |
Rock Crawler Join Date: Jul 2008 Location: San Marcos, CA
Did you add longer screws and add spacers inbetween? Try that it worked for me. hope this helps. -RCHuffer screw, axle mount, shock, spacer, axle mount, spacer, bent link, nut. |
02-03-2009, 09:52 PM | #4 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Thats the issue with bent links. Do like moabax said and you should be good. If not, search for TheRealDogman and his Dog-Leg bent links.
02-03-2009, 09:55 PM | #5 |
02-04-2009, 05:32 AM | #6 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
Its too bad you already bought those links. I think the Dogman links are bada**. Thats my next investment. The links were designed to alleviate that binding problem.
02-04-2009, 08:22 AM | #7 |
Rock Stacker Join Date: Oct 2008 Location: santa cruz
someware in here someone put a couple spacers under the lower spring cap and it gained enough clearance to not bind.
02-04-2009, 09:12 AM | #8 |
Pebble Pounder Join Date: Jan 2008 Location: E. Concord
to correct that problem i just got a new chassis and links all together but to do what the other guys said works, moving the links outside of the mount, did this on a friends truck
02-04-2009, 07:02 PM | #9 |
Thanks guys, Got it going today... Here are some specs: Integy drive lines rooster crawler esc 55T Novak motor JR racing Z650m servo Bent links F/R Red springs in front, blue in back Mirrored trans Locked F/R Drilled holes in all the rims Cut foams I have to admit I learned all this from you guys here.. Before the links |
02-04-2009, 07:10 PM | #10 |
Quarry Creeper Join Date: Aug 2008 Location: back where I belong
you arent using the right plastic rod ends the proper ones clear it just fine.
02-04-2009, 07:14 PM | #11 |
02-04-2009, 07:19 PM | #12 |
| i use the ones on the bottom right. |
02-04-2009, 07:25 PM | #13 |
Yeah I only had 2 left over after everything was done. I heard moving them in toward the drive lines was better anyways??
