02-10-2009, 09:42 PM | #1 |
Quarry Creeper Join Date: Jun 2004 Location: dsm IA
| bent rod ends??
ok guys ive been browsing the forums and noticed that alot of guys have a bent style rod end on the steering links and where the links mount to the frame. Am i supposed to use them on my steering and frame mounts instead of traxxas ends? im upgrading my rtr so i didnt know about them just knew about traxxas ends from tlts
02-11-2009, 12:16 AM | #2 |
Rock Stacker Join Date: Dec 2008 Location: oroville
i no wit alot of traxxas ends u got to watch ur wheel bais from front to bak wheel if doin comps. but i use the axial one that comes wit every end u need thats wat i run on mine ......
02-11-2009, 12:46 AM | #3 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
I use them to prevent any binding issues,and get the most flex, on the steering to keep distance from the axle and to lower drag link angles. Traxxas ends are supposed to be stronger.
02-11-2009, 01:03 AM | #4 |
Newbie Join Date: Sep 2008 Location: Melbourne Australia
I used revo rod ends and threaded rod/allthread to replace the plastic rods on my rtr. The only problem I found was that the revo ends are bulkier than the axial ones so I had to use spacers between the frame and the balls so the rod ends wouldnt rub on the frame. These are the mods I have made to my rtr using ideas and advice from this site, wheel weights replaced all the plastic links and inboarded them split battery pack on front axle four link top mounts front and rear relocated esc and receiver [traxxas 3 channel rx + tx used] 45 turn motor aluminium shocks [soon to be inverted] dig The links, top plates and dig I made myself using ideas from various threads here and had a great time doing so. Enjoy modifying your truck and keep us informed on how you go |
02-11-2009, 09:06 AM | #5 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
The Axial offset rod ends seem not strong enough for lower links. The straight ones seem to hold up. I've replaced my broken offset ones with straight ones and the difference in link clearance is not a big issue. If you are going to use bent lower links you should be fine with straight rod ends, they're stronger and you'll have more clearance anyhow. Cheers. |
02-11-2009, 10:06 AM | #6 |
Kyosho makes a 6.8mm offset rod end. They are an optional part for the Inferno's. I'd say they are about the same size as a Revo end. http://www.amainhobbies.com/product_...oducts_id/6047 And here's several different choices for balls in them: http://www.amainhobbies.com/advanced...sho+6.8mm+ball |
02-11-2009, 11:22 AM | #7 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
good info |
02-11-2009, 01:12 PM | #8 |
Rock Crawler Join Date: Jan 2009 Location: crawlorado
traxxas part number 2742 its a 6pack of rod ends and steel chrome balls 4.00 you can use the reg hardware that came with the aluminum links 3mm fine thread if you dont have the reg links (rtr came with plastic) artr and the unbuilt kit come with the alumminums i use them on all the links except the steering and my truck is still within comp limits
02-11-2009, 04:32 PM | #9 |
thanks guys if i read right i could use them on my steering(it is kinda close to the axle) but dont worry about the links?
02-11-2009, 08:02 PM | #10 |
Rock Stacker Join Date: Dec 2008 Location: Calgary-Canada
02-11-2009, 08:11 PM | #11 | |
Quarry Creeper Join Date: Nov 2008 Location: Lightin' The Desert In
02-11-2009, 08:11 PM | #12 |
02-12-2009, 07:53 AM | #13 |
