02-14-2009, 11:17 AM | #1 |
Newbie Join Date: Jan 2009 Location: MALTA
| Lowering my ax 10
Can anyone show me perhaps posting some images on how to lower the ax10 please? Cause i have no idea.:-(
02-14-2009, 11:32 AM | #2 |
These are their spacers to limit travel. I use two inside, under the piston to make the overall length shorter, and one outside to limit travel. http://www.tcscrawlers.com/search.ph...=search&page=1 |
02-14-2009, 04:06 PM | #3 |
Rock Stacker Join Date: Jan 2009 Location: Winnipeg, Mb
Also you can use some spare fuel tubing if you have some laying around instead of the plastic spacers just to let you know. |
02-14-2009, 05:38 PM | #4 |
Newbie Join Date: Oct 2008 Location: Northbay
Go with the rubber fuel line it works good.
02-15-2009, 02:04 AM | #5 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
If you do some searching you can also find some rubber stops made by HPI and they work really well for just about everything. http://www.hpiracing.com/products/en/87524/ or the ones I use are http://www.hpiracing.com/products/en/87058/ like these instead of fuel tubing because I was having trouble with the tubing collapsing and bunching up on me. |
02-15-2009, 03:54 AM | #6 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
you could use a shorter shock as well ...the losi and maxx shocks work well and get the height down
02-15-2009, 04:58 AM | #7 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
I got some plastic 3/16 x1 inch spacers at lowes and cut them down to 3/4 and put them inside the stock shocks. It gave me a 4 inch eye to eye on the shocks. It helped my rig handle alot better. |
02-15-2009, 09:08 AM | #8 |
Quarry Creeper Join Date: Dec 2008 Location: Suburbs
| I like that...been using this stuff all the time and never thought about using it on the shocks that way...nice!!! |
02-15-2009, 04:16 PM | #9 |
Thanks everybody for your help. Besides inserting the fuel pipe inside the shocks what about removing the springs? I saw some photos of the ax 10 without springs...........does this help And another question i have is on the tyres......some friends suggested me to remove the inserts to increase grip and leave the tyres empty.................any suggestions about this? Many thanks |
02-15-2009, 07:17 PM | #10 |
Rock Stacker Join Date: Nov 2008 Location: Santee
02-15-2009, 07:58 PM | #11 |
Fuel tubing works great and it is cheap. Just make sure you cut the tubing cleanly, I didn't and it split in the shock. Also, I recommend going with lighter springs, the stock springs are way too stiff for that (3lbs). In each shock I have 15mm of tubing with 1.7lbs springs in the front and 2lbs springs in the back, it seems to work really well with this setup.
