02-20-2009, 08:03 AM | #1 |
Pebble Pounder Join Date: Jan 2009 Location: Bucktown
| will alum tranny case help striped gears
well I have a custom super about 15 pounds with nylint 12volt battery. so my tranny (ax10) jumps teeth when in a bind, would the alum case maybe help. thanks bigger is better:-P Last edited by 12voltfun; 02-20-2009 at 01:38 PM. Reason: typo |
02-20-2009, 08:07 AM | #2 |
Quite possibly. Getting rid of some battery weight would help a lot too.
02-20-2009, 08:14 AM | #3 |
yes the weight is the killer, but i have like 10 or so nylint batterys and can't bring my self to spend the cash on new batterys and charger
02-20-2009, 08:27 AM | #4 |
Quarry Creeper Join Date: Apr 2008 Location: Racine
What would do more good is a DNA motor plate. The Axial motor plate has too much flex in it, so you'll strip gears all day long. The other thing you can do is install the slipper kit so that when you bind the slipper kicks in.
02-20-2009, 08:32 AM | #5 |
my spur gear is great the problem is the 3 internel gears in the case thanks |
