03-15-2009, 06:41 PM | #1 |
Newbie Join Date: Feb 2009 Location: manila
| What motor or pinion for RTR to slow it down Good day guys! I have an AX10 RTR all stock out of the box just want to know what's the cheapest way to slow this baby down. What motor (35T,45T,55T????) can I use without changing the stock ESC? Or can I just use a lower pinion gear (like 9 tooth maybe?) I'm on a tight budget right now so your inputs will really be helpful. Thanks in advance :-P |
03-15-2009, 08:23 PM | #2 |
Newbie Join Date: Oct 2008 Location: Alberta
Novak 55t is a great....cheap, motor upgrade. You will not have to change your ESC and it will run you less than $20
03-15-2009, 08:26 PM | #3 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
Yeah run a 55t with a 14 tooth pinion gear and you will be good |
03-15-2009, 08:35 PM | #4 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
Like they said, or if you want a little more wheelspeed go with a 45t. Even a cheap Integy will be a big improvement.
03-15-2009, 10:06 PM | #5 |
thanks for your inputs guys really appreciate it ,based on your own experience which is the better all around motor for crawling a 55T or 45T? thanks in advance
03-16-2009, 07:55 PM | #6 |
good day just want to know which is better for all around crawling a 45T or 55T motor your inputs will surely help so I'll just purchase the right motor the first time so as not to waste money. Tnx in advance:-P
03-16-2009, 10:26 PM | #7 |
Rock Stacker Join Date: Feb 2009 Location: Northern
the RTR has a 27t i think? I was runnin 27t in my artr untill my 55t came in. I would definatley get the 55t you wont have any problems crawling with it.
03-16-2009, 11:07 PM | #8 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
14T pinion (providied with the RTR) Novak Rooster Cralwer ESC 55T motor combo from tower hobbies |
03-17-2009, 12:34 AM | #9 |
thanks guys I think I'll go with the Novak 55T motor and 14T pinion for crawling and just swap the 27T axial motor w/ 20t pinion for bashing around |
03-17-2009, 10:13 AM | #10 |
Rock Stacker Join Date: Aug 2004 Location: holland oh
i run a 85 turn with 20t pinion
