| | #1 |
| Rock Crawler ![]() Join Date: Jul 2006 Location: barstow
| so does anybody else have problems with bearing fitment on vanquish ax10 knuckles. this rig i bought has brand new knuckles and there is so much slop in the bearing fitment its unreal im afraid to run the truck with as much slop as this thing has. its mainly on the inner bearing with the wheels snugged down you can grab the wheel and rock it back and forth and watch the bearing moving around ? |
| Sponsored Links | |
| | #2 |
| Damn-I need a chump RT!!! ![]() Join Date: Sep 2007 Location: Lost as hell.....
| Thats strange, I own 2 sets and I think they are machined and fit nicer then any other knuckle I have ran......... I would contact Vanquish, I sure they will take care of you. |
| | #3 |
| Well then.... ![]() Join Date: Feb 2008 Location: NorCal
| x2 here, I just put a set on one of my rigs and the bearing fitment was great. Are you sure they are vanquish knuckles? Not trying to single CKRC out, but any chance they may be CKRC ones? I know they had a bad run of them when they first came out and there was some delay in getting the machining right.... |
| | #4 |
| Rock Crawler Join Date: Nov 2008 Location: I don't think theres rocks in Florida
| x2 Steve and the guys at Vanquish are top notch. Those bearings should fit like a glove. I had to slide mine in perfectly str8, or they'd bind and stop. I just got mine and I'm not finished with my build, but they are hot! |
| | #5 | |
| Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
We had 3 sets to try but they all bind so bad ya can't even run em also; some had a nicer finish,and some others had a sharp raw cut finish,so no set matched. After waiting over 2 months for them,the final reply was "how bout a 10% discount on the next order,ROFLAO | |
| | #6 |
| Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
| Are you sure it's not the bearing? Is it original? Metric, not imperial size? Bearing not worn or damaged? Cheers. |
| | #7 |
| That Was Totally Ninja! ![]() Join Date: Mar 2004 Location: Whore Island
| Your knuckle should have a little "VP" engraved on it if it's a Vanquish... |
| | #8 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| That's what I was thinking. It'd be super easy to pick up the wrong bearing. If the bearing was the wrong size or worn,even just .005"-.010" different could make allot of slop out at the wheel. |
| | #9 |
| yeah they have a VP in the top of each knuckle and from what i can tell these parts are all brand new. the guy who built it never ran it other than in the kitchen to check all the settings. you guys do bring up a good point about the bearing i will take my scx10 apart and check that bearing fitment before calling VP. they look very top notch quality and everything i have read about VP is the same thats why i was wondering if maybe i just got a bad set. i will post up what i find. disclaimer: in no way am i trying to flame on VP just looking for ideas or help Last edited by rcjunky3; 04-11-2009 at 03:49 PM. |
| | #10 |
| Rock Crawler ![]() Join Date: Jun 2008 Location: Sacramento
| if there is a problem, shoot us an email and we will take care of it right away of course. We have not yet identified any bad tolerances on the bearing fit in our inventory. |
| | #11 |
| message sent |
| | #12 |
| Pebble Pounder Join Date: Mar 2008 Location: upland
| VP products hav warranty and i hav several products of theirs and all is better than the rest |
| | #13 |
| Quarry Creeper ![]() Join Date: Mar 2004 Location: VA
| I think some of the first ones may have an issue , I just got a set (from RPP ) and one is sloppy and the other is good . I haven`t called about it yet but know I will be taken care of when I do , not worried . I`m going to mic the bearings first to rule that out. A friend also had an issue with his last week and it`s already been taken care of . |
| Thread Tools | |
| Display Modes | |
