| | #1 |
| Newbie Join Date: Mar 2009 Location: newcastle england
| hello peoples im fairly noob but i bent my rear axle on my ARTR and the wheel started to wobble a fair bit. i ordered a new set (ax30421) and they came with washers that i assume are shims. i took the bent one out and it had none on (i slid it out the end?). do i need to put them on and if so were exactly do they go? |
| Sponsored Links | |
| | #2 |
| ......../-__-\........ ![]() Join Date: Nov 2007 Location: Memphis
| they go in between your axles and bearings, and that's IF you need them. You may not depending on the fit. If your axles wobble in and out after they are installed, install a few shims. |
| Thread Tools | |
| Display Modes | |
