| | #1 |
| Quarry Creeper ![]() Join Date: Oct 2008 Location: Reno, NV
| i just ordered the edge chassis from the crawler store and was just wondering when you get the droop hardware do you run eny shock oil in the shocks with it. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
| Yup, your shock oil will play a big part in how well the shocks react when you go to that droop setup. You'll have to test and tune a little and run a fairly thick oil in them. |
| | #3 |
| | #4 |
| and do you run it above the piston or bellow |
| | #5 |
| Rock Stacker ![]() Join Date: Apr 2007 Location: Nor Cal
| More then likely below. |
| | #6 |
| | #7 |
| what kind of shock oil do you guys run |
| | #8 |
| Rock Crawler Join Date: Mar 2009 Location: Victoria BC
| i run 70 wt in all 4 in my set up, i'm set up with drrop useing clicky pen springs |
| | #9 |
| | #10 |
| Ttt Last edited by jdacus; 04-16-2009 at 11:16 AM. |
| | #11 |
| | #12 |
| | #13 | |
sorry i missed your question, when you fill you shocks i leave the oil down about 1/8" from the top of the shock. your running the spring under the piston? thats whats stoping it fron drooping out, not the oil, the oil controlls how fast the wheel can move in / out the spring controlls how much force it takes to do so, remember that the spring inside the shock limets the overal travel of it, by about 1/4" from stock set up. the way i am set up is as follows. rear : 2 pen springs inside the shock under the piston to keep the shock compressed at all times unless flexing, useing 70wt oil with 2 oz in the wheels front: one pen spring inside and one pen spring out side with 70wt oil, i have about 5.5 oz in each front wheel and this allows the shock to drop out to full extention but keeps it sucked down when side hilling. every one is going to have different preferances on what works and what doesnt Last edited by ultimate_monkey; 04-18-2009 at 11:44 AM. | |
| | #14 |
| so mabe i should try a soft spring istead of a med |
| | #15 |
| ya medium is probably to stiff to let the shock drop out freely, so go to a softer spring run more weight in your wheels, the springs i am useing literally came out of a clicky pens, i got 12 pens for 1.50 at the doller store, and IMO it works just as good as buying a droop kit from a retailer |
| | #16 |
| Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
| | #17 |
| Quarry Creeper Join Date: Dec 2008 Location: Leesburg
| I'm running the TCS medium internal springs in my droop setup, they are a little stiff, but i run heavy rims and axles so it compensates well. I also run 70 weight oil in the front and 35 weight oil in the rear, seems to work out real well for me |
| | #18 | |
| Quarry Creeper Join Date: Feb 2009 Location: Richmond, VA
| | #19 | |
heres the best i feel like doing now haha, its basically the same now except i have taken the fule tube off the rear shock spring or not | |
| | #20 |
| If you do a search on "droop" you'll come up some up with lots of good threads here's a few http://www.rccrawler.com/forum/showthread.php?t=72831 http://www.rccrawler.com/forum/showthread.php?t=65382 http://www.rccrawler.com/forum/showt...t=98885&page=4 |
| Thread Tools | |
| Display Modes | |
