| | #1 |
| Quarry Creeper Join Date: Apr 2009 Location: Ukiah
| Just wanted to introduce my self as I'm new here. My name is Eric and I have a stock ax10 Scorpion that I just got today, it's the RTR. My brother in law gave to me as an early bday present. I also have a traxxas Rustler VXL thought I bought about 2 months ago. Eventually I would like to do comps but first I need to learn how to crawl. I already have a small list of parts that I would like to upgrade and was wondering if anybody would like to suggest things to put on my list. I look forward to learning and contributing to this forum. Eric |
| Sponsored Links | |
| | #2 |
| Quarry Creeper ![]() Join Date: Oct 2008 Location: Reno, NV
| well you could start with a new body because the stock rtr bodys mess with the tires to much |
| | #3 |
| Rock Crawler Join Date: Mar 2009 Location: Victoria BC
| intall the provided front axle locker. swap on the 14tooth pinion gear get aluminum links and steering, new tires, upgrade the servo, . higher turn motor, better esc those would be what i would look at upgradeing first |
| | #4 |
| RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| I would trim the stock body so that my wheels have better clearance. Make sure you put your locker in the front. Replace your plastic links with metal ones. A metal gear steering servo would be a good idea, because those plastic ones won't last that long. I would also upgrade my tires, because the stock ones "SUCK". There are a ton of things that you can do, but I don't want to break your bank this early in the game. Me and my freind run our ax10 at Lake Mendo on Sundays around 10am to 11:30 am so stop by if you wants some one to test your skills with. Won't be there this Sunday, because I'm going to a RC ROCK CRAWLING COMP. Welcome to the hobby. |
| | #5 | |
Eric | |
| | #6 |
| Rock Crawler Join Date: Jul 2008 Location: San Diego
| The plastic link will bend all over. I run delrin links home made. About 1.00 a foot. 4 link plate from STRC. 12t pinion will slow your truck a little. Latter on Tekin FX R and 45t motor. The HPI tires are most likely the best tires I have used. There cheep here. http://www.tcscrawlers.com/ON-SALE-7...2-p-17154.html MIP drive shafts or traxxas drive shafts #1953. Rod ends for aluminum links traxxas # 1942 very strong and cheep also. 12.99 for 2 tires! Thats cheep for a great tire. Have fun. I started with a RTR. Almost nothing left of the RTR except the trans and axles. Hope that helps Matt |
| | #7 |
| I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
| Tires (rovers/cougars/comps), small pinion/large spur, Servo!, 4link the rear, get the battery off the roof, softer springs and the list goes on. |
| | #8 |
| Newbie Join Date: Aug 2008 Location: yreka
| white rover tires. those plastic links after a while will turn into spaghetti. i have the tekin 55t motor w/ tekin fxr esc. i love it. and different body or trim the stock one. hope this helps |
| Thread Tools | |
| Display Modes | |
