Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Best place to put 7.2v battery pack
Old 04-17-2009, 07:46 AM   #1
Default Best place to put 7.2v battery pack
Where is the best place infront near the steering servo or behind on the place were the rear steering servo is supposed to be? Thanks as al2ays for your help
xxinterboyxx is offline   Reply With Quote
Old 04-17-2009, 08:44 AM   #2
If don't don't have a pre build stick pack. (I assume you are refering to a NiMH pack) I split mine up in to 3 side by side cells and placed each one over oppositE corners on the axles. Right front and left rear. This helps with the infamous torque twist and still maintains a good cg.
nevrdun is offline   Reply With Quote
