Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Aluminum C hubs and knuckles?????
Old 04-17-2009, 02:27 PM   #1
Default Aluminum C hubs and knuckles?????
hello fello crawlers,
my question is does replacing the plastic stock C hubs and knuckles with aluminum ones change the performance of the crawler? Does it really give you that much more turn radius? what else what i benefit in if i was to replace these parts with aluminum ones?
also if it is better to replace these parts what parts would you guys recommend to replace with.? the aluminum axial C hubs and knuckles? or another brand? any input will help..
thanks
lildjloop is offline   Reply With Quote
Old 04-17-2009, 02:41 PM   #2
Latest NorCalRCRC slave
gunnar's Avatar
The "C"s are stronger, The knuckles are stronger and will give you slightly more throw, but CVD's will give you around 45 degrees of steering movement. Several companies offer these parts, go with what you feel is best.
gunnar is offline   Reply With Quote
