04-21-2009, 09:48 AM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Houston
| springs??
my question is what type of spings do most of crawlers run and what tension do most run on rear shocks? please help, looking to replace springs. thanks |
04-21-2009, 09:57 AM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
2 clicky pen springs per shock, rer both inside under the piston, and front one inside one out side... but if you just want to keep the stock set up, soft front and medium rear seems to be the commen option |
04-21-2009, 05:00 PM | #3 |
Newbie Join Date: Mar 2009 Location: flint
ive noticed a lot of ppl saying clicky pen springs, but any particular ones? ive noticed there are about 100 diffrent sizes, and what config exactly? any body have a build pic of the shocks?
04-21-2009, 05:27 PM | #4 |
| Who you listening to? I run the red coded Axial springs all around. White are the second softest, you could try those to start. I also have two of the little rubber limiters inside under the piston to shorten the shock. And one outside to limit the travel. Funny how Axial now makes shorter shocks on their new RTC. Experiment, there's no perfect set up. |
