05-13-2009, 07:10 PM | #1 |
Newbie Join Date: May 2008 Location: granite falls
| slingshot, revo shocks, tire rub problems??
i have a slingshot with revo shocks and a ckrc bta steer kit...the shocks are upside down and there are no spacers at the top where they attach to the chassis...soooo the problem is when i turn the tires lock to lock they rub the springs like crazy...is there a fix for this and how?? Last edited by robchas; 05-13-2009 at 07:20 PM. |
05-13-2009, 07:50 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Southwest VA
Mine rub the springs also. Not too much, I backed off the end points for the steering just a bit so the tires would not try to grab the springs. I also used a zip tie around the end of the spring and the spring cup to help hold everything together when the tire rubs the spring. Is the shock attached between the tabs on the axle on your rig? Kinda hard to tell from the pics. pic of mine, steering isn't at full lock in this pic but it is pretty close. |
05-13-2009, 07:56 PM | #3 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
I am running losi shocks on one rig and slash front shocks on the other. No matter what i tried they both rub alittle. But just barely with the slash shocks! |
05-13-2009, 08:02 PM | #4 |
Pebble Pounder Join Date: Nov 2007 Location: Santa Ana*O.C.
i had a shafty slingshot and ran .6 losi shocks with zero rub issues |
05-13-2009, 08:11 PM | #5 | |
the shocks are inside the axle tabs and i've changed my end points so it does not rub bad....but that takes away alot of steering that i could be using....i was just wandering if there was a fix or trick for this problem... | |
05-13-2009, 08:33 PM | #6 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
this is what i did. used revo shock rod ends and mntd them like you see.inside the chassis. and mntd the bottoms on the inside of the tabs on the axles. |
05-13-2009, 09:46 PM | #7 |
Quarry Creeper Join Date: Feb 2008 Location: Citrus Heights
rotate your pinion down and clock your axle "c"s back. with all that positive caster how does it turn? that should buy you some more turn radius.
05-14-2009, 02:41 AM | #8 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
I am just using jato shocks with my SS and the tires used to rub axial rims. So I tried using berg offset wheels and now the tires barely touch the springs even with the chisels that are taller. The slghtly extra width was also useful.
05-14-2009, 07:28 AM | #9 | |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
Here's a solution: run without springs slingshot + droop revo shocks = stable, low, and sticks to rocks | |
05-14-2009, 12:55 PM | #10 |
| From what I can see, berg stock rims are more offset than axial rims. I may be wrong. I tried that droop, sag or whatever and it just is not for me. Rig is very unpredictable for my taste.
05-14-2009, 01:42 PM | #11 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
You could always run internal springs and not have to worry about tire rub. Thats how I have my GTR shocks setup.
05-14-2009, 02:20 PM | #12 |
05-15-2009, 01:46 AM | #13 |
05-15-2009, 02:07 AM | #14 |
RCC Addict Join Date: Apr 2006 Location: On Da' Shelf
Could'nt find that part #? Are there any issues with the spring doing damage to the bladder inside the shock? |
05-15-2009, 02:21 AM | #15 |
So far havent seen any damage. Here is the spring set http://www.tamiyausa.com/product/ite...oduct-id=40501 I used it full length. With the little bump stop on the shock the spring doesnt compress all the way and there is no binding. If you want to be sure it doesnt damage the bladder you can sand the end of the spring smooth and that should keep any sharp edges from puncturing the bladder. |
05-15-2009, 02:46 AM | #16 |
Kewl ThanX for the link.
