06-08-2009, 09:12 PM | #1 |
Newbie Join Date: Jun 2009 Location: duanesburg
| new to crawlers, looking for some advice
i recently picked up a ax-10 scorpion and was wondering what battery would be good to use. i was looking at maxamps but they have alot of batteries to chose from. i am using the stock axial esc for now, i ordered the 55t axial motor i figured it was cheap enough i could give it a shot. i also got the alum link set since the toe link flexs so much. anything else i should do for starting out? any help is appreatiated thanks, nick
06-08-2009, 09:17 PM | #2 |
Pebble Pounder Join Date: Apr 2009 Location: West Monroe
7.4 2cell lipo i would get a minimum of 1500mah. Max amps is really high check out the zippy battery packs they are awesome or i am running a venom lipo,.
06-08-2009, 09:19 PM | #3 |
Newbie Join Date: May 2009 Location: Boise, Idaho
The first thing I would do is switch out the the three link setup for a four link one. The second thing i would do is buy a BEC and a new ESC ( castle is good ) that will allow you to run 3s lipos. The last must is new tires, claws, panthers, rovers any of these will do you well! If you do these things and weight your rig right you should do pretty ok.
06-08-2009, 09:20 PM | #4 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Weight your wheels! Two wraps of stick weight like you see on a 1.1 wheel on the fronts and half of that on the rear. Change those tires if you have the lizards still. Check out cheapbatterypacks.com for a saddle pack front axle mount battery. Strait axle kit if it didnt come with it. Never owned a RTR so I dont know what they come stock with. Rooster crawler or tekin speed control. Softer front springs. White or red. start there. Also the servo on the stock one is weak. Upgrading that to a high torque metal gear one will be good.
06-08-2009, 10:28 PM | #5 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
check out the cheap tips and tricks thread in this forum. get some bic style pen bodies and cover the links you just got with them. You can get colored pen bodies free from banks and such. the alum. links grab the rocks, delrin ones or the covered one will slide over the rocks like butter. You can get a slightly use pair of tires from here for a good price but ditch the stockers. Panthers are my favorite. You'll get good results with those two but you'll want to step up to a better ESC. soon. as well as a better front servo. the Towerpro ones are around 25 $'s for a 208oz.
