06-17-2009, 09:09 PM | #1 |
Quarry Creeper Join Date: Jan 2006 Location: PNW
| RTC leaking shock
got 1 leaky shock, I'm a newb to hobby grade RCs. I've trashed plenty of throw away cars. Any how, I've done some searching, haven't really found a good answer short of rebuilding. Which I don't know where to start, I mean the shock bodies are plastic, I would think wrenching on them in any sort of way would just fubar them up. I read a thread that said to tighting the cartridge up? Only thing I see that you might be able to tighten is on the bottom there is uhh I would say 10mm hex nut molded into the plastic, I don't know if wrenching on it would round off the threads. When it comes to tightning to I do have a heavy hand, and tend to strip or round things off quite frequently, so I'm trying to be as dainty as possible. Thanks! |
06-17-2009, 09:17 PM | #2 | |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
06-17-2009, 09:28 PM | #3 |
Thanks a bundle, after I posted I decided to fart around a youtube, seems fairly simple other then the fact I'm dealing with plastic shock bodies rather then metal. I don't have any shock oil on hand, will have to pick some up. Not sure what weight is in there from the get go. I'll try that and if it continues to leak, may see about upgrading to the metal aluminum shock bodies. Last edited by Chuki; 06-17-2009 at 09:31 PM. |
06-17-2009, 09:40 PM | #4 |
Newbie Join Date: Jun 2009 Location: veneta
ya Ive got the same prob on my ax 10 stock shocks so im thinking of using some teflon tape and see if that work and if not I guess im going to shop around
06-17-2009, 09:41 PM | #5 | |
No problem. Metal shock bodies would be a good idea. The Crawler store has some nice aluminum shocks in various lengths that are very affordable and the quality is good. Try this link http://www.tcscrawlers.com/Shocks-Sh...p-1-c-279.html I have the yeah racing ones on my truck. I like them so far. | |
06-17-2009, 11:28 PM | #6 | |
I'm not blaming anyone, I'm wanting to know how I can fix it, I know there is better out there. There will always be better, I want to fix what I have. | |
06-18-2009, 12:10 PM | #7 | |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
06-19-2009, 11:06 AM | #8 | |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
I would suggest remove the bottom cartridge, carefully check all the seals for cuts or tears. If all good, clean it up good, top up the oil (30 Wt. should do) then screw it in tight by hand, and see how it goes. Cheers. | |
06-19-2009, 11:53 AM | #9 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
These new shock are awesome, as I've said before. Even the plastic versions are silky smooth. I'd just try topping them off with oil and tightening the top cap and lower cartridge. Teflon tape isn't a bad idea either. | |
06-20-2009, 12:24 AM | #10 | |
The local hobby shop here is nothing but planes, but they can order it for me Also would it be advisable and is there such a thing as boots for these things? My crawl pile in my backyard also has alot of loose dirt. Is this going to pose a problem? Thanks again, you guys rock! Last edited by Chuki; 06-20-2009 at 12:29 AM. | |
06-20-2009, 12:30 AM | #11 |
| I think motor oil will eat the o-rings as it is hydrocarbon based, shock oil is silicon based.
06-20-2009, 12:33 AM | #12 |
| That post was a reply to what appears to be a deleted post, basically poking fun at axial, stating its a design flaw. I don't think it is, I was simply stating that since I play around in a rather filthy enviroment that could have caused it. I also did get a good turn on the bottom cartridge (10mm nut), but haven't had time to play yet, but it is low and needs to be topped off anyway.
