06-26-2009, 07:56 PM | #1 |
Newbie Join Date: Jun 2009 Location: Stoney Point
| Tries Rubbing on front links?
I just got my AX-10 yesterday, i'm rinning a novak rooster/55T combo. This thing is amazing, but when making a hard left or right turn the tires rub on the links. I checked everything over and it all looks good what would be causing this? Also when reversing it makes a clicking noise... is that normal? Thank you for your help, What a great forum |
06-26-2009, 08:21 PM | #2 |
Newbie Join Date: Dec 2007 Location: NYC
adjust your servo....i had the same thing...when i adjusted it..worked fine
06-26-2009, 08:23 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Either limit the servo throw or change the link position on the alxe. If you can inboard them on the chassis side(triangulate them) you can move them closer to the center of the axle.
06-27-2009, 11:06 PM | #4 |
Rock Stacker Join Date: May 2009 Location: Baton Rouge
06-28-2009, 06:13 PM | #5 |
Newbie Join Date: Jun 2009 Location: Saint George
Or you can buy some high clerance links and turn them in towards your rig so it gives your tires more room, cause the more steering the better...
06-28-2009, 07:28 PM | #6 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
You could space your front wheels out a bit, Or change where shocks and links are mounted on the axle via. longer bolts and spacers. Move the links inbored on the skid plate side of the chassis. That should take care of it, and they wont hang up on rocks as much. |
