06-28-2009, 06:04 PM | #1 |
Newbie Join Date: Jun 2009 Location: Saint George
| Torque Twist
What is the best way to try and get rid of torque twist....
06-28-2009, 06:09 PM | #2 |
Pebble Pounder Join Date: May 2005 Location: hot springs, AR.
Split the upper links to a true 4 link. Then move the lowers in close together at the chassis to give the suspension good triangulation with the uppers spread. And add under drive gears to the rear. Cost yah about $60 bucks in parts.
06-28-2009, 06:11 PM | #3 |
Try the search button. There are tons and tons of threads dealing with this issue. |
06-28-2009, 06:15 PM | #4 |
k. i have the 4 link servo plates set up. but have not moved anything around...
06-28-2009, 11:02 PM | #5 |
Newbie Join Date: May 2009 Location: Warrenton
Move your shocks to the outside of the axle and move you lower links inward on the axle and the chassis, I got my spur and pinon gears facing the front and it works for me. I still have a 3 link and it got rid of of my TT.
06-28-2009, 11:18 PM | #6 |
Rock Stacker Join Date: Apr 2009 Location: Union
I did the four link in the rear Left link on top of plate right link below plate, helped some. flipped trans helped some, finally added one thick preload spacer to the left rear shock, i can now make this thing wheelie when geared right. It will pull both front tires straight up in the air from reverse to forward. Funny thing about always posting Try a search is, you get lots of threads that simply say to try a search and can be discouraging to new members and to new people who may not be completely familiar how a message forum works, im sure everyone here has posted before searching when there is multiple threads on a subject |
06-28-2009, 11:21 PM | #7 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
The 2 things I would recommend is putting a heavier shock oil in the left rear shock and the Axial Optional Gears. The search feature is great on this site you just have to be very specific. Another thing I would do is Look up a build thread for either Bender or Gatekeeper. These are 2 of the best Axial drivers out there
06-28-2009, 11:38 PM | #8 |
Run more anti squat on the side that squats.
06-28-2009, 11:40 PM | #9 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Try mirroring your trans too.
06-29-2009, 01:26 PM | #10 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Longer upper links in the rear running parelell (sp) with lower links pinned in at the chassis. Like this I/\I then move your rear shocks out to the farthest point on axle...may need to space them out some at the chassis too if they feel like there binding.
06-29-2009, 02:03 PM | #11 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
Lots of good advice in this thread. You will never get rig of Torque twist but you can reduce it. Easy and cheap fix is put a spacer and/or stiffer spring on the left rear shock. A 4 link will help as well (as stated in another post) |
06-30-2009, 03:24 PM | #12 |
Thanks, i will switch some stuff aroud and see how it does in the comp on July 11th... you guys all rock... |
06-30-2009, 10:23 PM | #13 | |
Pebble Pounder Join Date: Dec 2008 Location: MIDDLE TN.
JEFF | |
07-01-2009, 11:07 AM | #14 |
07-01-2009, 12:36 PM | #15 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
| wow I tried that last night and man what a difference it made. As soon as I clicked the search button all my torque twist issues went away. Thanks man you have really helped me out. |
07-01-2009, 02:21 PM | #16 |
i found lots of threads that say to search, buried way way down the list is the answer to most of them, talk about a waste of board space
07-01-2009, 06:53 PM | #17 | ||
My point was, if you spend a little time looking before asking, you'll usually come up with your answer, and it'll happen much faster than posting and waiting for a reply. Theres also a great thread on setting up a 4-link, but I'm not going to tell you where it is. | ||
