Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: axial zero backlash gears
Old 07-09-2009, 12:19 AM   #1
Ty
Ty's Avatar
Default axial zero backlash gears
Can anyone point me in the direction of such a thing. I saw these some where but now I can't find them, I think. My truck has a lot of roll before the slop is taken up in the gears. Thanks for the help
Ty is online now   Reply With Quote
Old 07-09-2009, 12:21 AM   #2
I believe it's not the gears so much as it is the locker and the dogbones. CVD's help along with an upgraded locker like the maximizer or the upgraded axial one. There are new ring and pinion sets out for it that are spiral cut but i'm not so sure they help any with your probelm.
racer22 is offline   Reply With Quote
Old 07-09-2009, 12:41 AM   #3
felsenfest
EGRESSor's Avatar
FELSENFEST AX10 spools (locker)
that may help
EGRESSor is online now   Reply With Quote
Old 07-09-2009, 01:02 AM   #4
I did the overdrive gearing in the front of mine and it took a lot of play out of the whole front drive train. I wish I would have gotten the HD rears too.
93yoda is offline   Reply With Quote
Old 07-09-2009, 08:49 AM   #5
Ty
Ty's Avatar
thanks for the info, I saw those spools a while back. I forgot that it was the spools and not the gears thanks
Old 07-09-2009, 08:53 AM   #6
TEAM MODERATOR
Reflection's Avatar
Pick up some shims at your local hobby shop. Shimming the gear mesh a little tighter will help. I shim all my diffs in my shaft driven rigs. Helps me allot.
I agree with the rest though,a good locker and CVD's help a bunch.
Reflection is online now   Reply With Quote
Old 07-09-2009, 09:50 AM   #7
dkf
Have a part # or the dimensions of the shims. My closest LHS is kinda useless and will probably have to order.
dkf is online now   Reply With Quote
Old 07-09-2009, 10:07 AM   #8
felsenfest
EGRESSor's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXUSG6&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXGPA7&P=7
Old 07-09-2009, 12:35 PM   #9
The HD overdrive front gears don't seem to have alot of play right out of the box. Probably a more quality part then the stock ones.
Old 07-10-2009, 07:27 AM   #10
dkf
Thanks EGRESSor.
