07-15-2009, 11:24 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: Mesquite
| Battery plate
I got a used battery plate for my fornt axle but without hardware. Can someone tell me what length spacers and screws I need where it bolts attatches on the ends?
07-16-2009, 01:22 AM | #2 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
The spacers for the axle are 20mm long and you need 2 3x22mm flathead screws to bolt them up. The steering post is also 20mm long for the short side and you use your stock rod ends. If you want a longer steering link then use a ~68mm long post and attach it to the opposite knuckle.
07-16-2009, 06:33 AM | #3 |
Thanks.
