07-25-2009, 01:48 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: PT
| Need help for this modification
Hi , I replace the upper rear links with shocks with inside springs and I would like to known if do you think this a usefull modification or not , please watch the video http://www.youtube.com/watch?v=OS1xHCkJIxk , many thanks in advance
07-25-2009, 02:56 PM | #2 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
IMHO I don't think that is going to be helpful, all It really seems to do is change your pinion angle. and I don't think that is a good thing.
07-25-2009, 03:05 PM | #3 |
Pebble Pounder Join Date: Oct 2008 Location: KY
i think that thats going to change your pinion angle to much and well that could be bad
07-25-2009, 03:06 PM | #4 |
thanks for your reply , and if I use this in the front do you think is usefull ? To push the font to the rocks
07-25-2009, 03:06 PM | #5 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
very bad idea
07-25-2009, 03:29 PM | #6 |
Rock Stacker Join Date: Jun 2009 Location: Cameron Park
not a very good idea all that is letting the axle do is move the pinon up and down. It could be very unpredictable.
07-25-2009, 03:37 PM | #7 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
The only thing that will do is bust driveshafts.
07-25-2009, 04:02 PM | #8 |
The concept behind suspension links is to have a controlled axle movement. With that setup, it goes where it wants when it wants. Definitely not a good idea. And who gave this thread 5 stars? |
07-25-2009, 04:26 PM | #9 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
Not a good idea, but I see where you are going with this. If you could pre-load the axles when climbing it could keep the tires from unloading maybe? It would just make the truck too unpredictable. Besides the fact the axle would walk side to side because you dont have that solid triangulation anymore. I just adjusted my pinion angle in the rear to as close to a straight line as possible and get my caster as close to perpendicular to the ground as I can. I like the "outside the box" aproach though. |
07-25-2009, 05:06 PM | #10 |
ok , thank you very much , IŽll keep the old fashion links and forget this idea
07-25-2009, 07:55 PM | #11 |
Pebble Pounder Join Date: Jul 2009 Location: Lehigh Valley, PA
in a three or four link suspension system, the lower links locate the axle and the upper link(s) set the pinion angle. Replacing the upper links with shocks will just introduce axle wrap into the equation (thats bad). Where you do see a setup like that is in a leaf sprung suspension system. Leaf springs by nature allow axle wrap, so a lot of drag racers and others with go-fast cars and leafs in the rear will install a shock (not a regular suspension shock, though) like that to help control the axle wrap. Crawlers, on the other hand, aren't worried about going fast so usually they'll just use a ladder bar instead. |
07-26-2009, 11:11 AM | #12 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
A little bit of axle wrap is not a disaster, but that is way too much! I once had a car with a four link and coil sprung rear end, and had dampers under the lower links. They didn't prevent axle wrap, but they eliminated the choppiness under hard acceleration, made it feel glued to the road. I can see that if set up properly it could do that for a crawler too, but do ya think you need to? Cheers. |
07-26-2009, 11:19 AM | #13 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
I think MEDIC used stiffly sprung shocks on his rig as upper links, but he used it with a dig to get more "bite" for the rear tires. You should PM him for his thoughts and ideas.
07-26-2009, 12:27 PM | #14 |
thank you very much , I watch Medic video on youtube and I had a pair of old buggye shocks and give a try without dig but I already give up the idea , IŽll keep it simple like everyone does , or almost everyone Last edited by barebones; 07-26-2009 at 12:31 PM. |
