07-26-2009, 03:48 PM | #1 |
Rock Stacker Join Date: Jul 2009 Location: san diego
| painting ax-10 stock beadlocks?
I was wondering if any one has painted there stock bead locks. and if u have what prep did u do and what type of paint. Also did it stick well? if you got pics that would be awesome as well. thanks
07-26-2009, 05:27 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
get them powdercoated
07-26-2009, 05:30 PM | #3 |
how much was it? do they chip?
07-26-2009, 06:48 PM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: Colorado springs
i think going to the home depot type store you can find some spray paint for them maybe that stuff for patio furniture that paints on plastic and metal as for prep prolly scrub them down they are stock and its only a matter of time till they strip or crack this way its dirt cheap one can for a hundred applications
07-26-2009, 07:30 PM | #5 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
are you talkin the rings or the rims? you cant poweder coat plastic (the rims) but you can paint them, as far as the rings, if your lazy u can just paint over the anodizing and if not use some oven cleaner (search for how do to it) then paint the bar aluminum or powder coat
07-26-2009, 08:34 PM | #6 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
I painted mine, just used some Ace hardware paint after I sprayed them with brake cleaner. I painted the rings too after I stripped the anodizing off and cut out the inner ring to make a teeth like pattern.
07-26-2009, 08:39 PM | #7 |
Quarry Creeper Join Date: Sep 2008 Location: So.Orange County
If it the wheels, you can also use RIT dye in boiling water.
08-09-2009, 07:06 PM | #8 |
Newbie Join Date: Dec 2008 Location: spokane
i painted mine, the paint just gets scratched off by the rocks
08-17-2009, 02:49 PM | #9 |
Newbie Join Date: Aug 2009 Location: kootenays,b.c.
oven cleaner and krylon hammered finish works great, be sure to scuff em up after the oven cleaner
08-17-2009, 04:05 PM | #10 |
Newbie Join Date: Jun 2009 Location: Australia
Etch primer is what you want to use, just give them a quik rub down with sandpaper followed by prepsol...prime then paint.
08-17-2009, 08:22 PM | #11 |
Quarry Creeper Join Date: Jul 2009 Location: SW Hell
Zinc-Chromate Primer is made to self etch Aluminum,Thats what I used I/o's at the Marina I used to work at.
08-18-2009, 03:27 PM | #12 |
Newbie Join Date: Mar 2009 Location: k ville
