08-29-2009, 10:02 AM | #1 |
Pebble Pounder Join Date: Jan 2007 Location: Clarksville
| where to get just the alloy steering links
cant seem to find just the 2 alloy steering links for ax10. all i have found is complete color packs but dont need everything in that. is it offered anywhere? im looking for green.
08-29-2009, 10:06 AM | #2 |
Quarry Creeper Join Date: Aug 2008 Location: Texas border crawlin from cops
I think STRC offered those. Or try corey from RPP
08-29-2009, 10:09 AM | #3 |
Rock Crawler Join Date: Nov 2008 Location: Sunny Southwest Florida
I would say check the vendor area and look for CPE I think they have some killer links. I use there high Clearence front steering link and it Rocks.lol
08-29-2009, 10:17 AM | #4 |
found these for rear steer. i assume they are same as front? http://www.teamstrc.com/ebproductdet...inid=15&id=199 |
08-29-2009, 10:29 AM | #5 |
yes they both can be used in the front too. 106mm and 33mm post I believe. Are you mounting your servo in the middle?
08-29-2009, 10:30 AM | #6 |
If you are then its the same length
08-29-2009, 10:31 AM | #7 |
yeah, havnt moved servo yet because as im building this rig up from a ax10 rtc, im slowly going to convert it 2.2 scaler. right now just small things that will work on both ax and scx, then ill get scale frame.
08-29-2009, 10:36 AM | #8 |
great. |
08-29-2009, 10:42 AM | #9 |
thats why i just want the steering links and not the color pack w/ the high clearance links - since will be going scale. if i could find the color pack w/ straight suspension links and steering links, that would work but havnt found that.
08-29-2009, 10:49 AM | #10 |
Youre right. You have to have direction or else youre going to end up having so many useless parts that you cant even dispose. or you can build 2 rigs and in that way, you can use your left over for either one of them.
08-29-2009, 11:19 AM | #11 |
Rock Crawler Join Date: Jan 2006 Location: Phoenix
here are the axial part numbers for the steering links, These are both green Ax30441 for the 6x106mm one and ax30442 for the 6x33 mm one, TCS has them both, you will also need ax80005 for the rod ends and axa186 for the 3x16mm set screws. |
08-29-2009, 12:19 PM | #12 |
Thanks. Do i need the long set screws or normal? They have both under that part number axa186. Also, do u know the straight suspension links part number for alloy? Last edited by neuro242; 08-29-2009 at 12:23 PM. |
08-29-2009, 12:38 PM | #13 |
Part axa186 is for the long ones, 16mm long the part number for the lower suspension links is ax30443 and the uppers are axa1319 those are for the green ones also Link to the kit manual http://www.axialracing.com/ftp/pdfs/AX90001-I002.pdf Last edited by Ghost; 08-29-2009 at 01:23 PM. |
08-29-2009, 12:46 PM | #14 |
great! thanks. ive been having a hell of a time finding upgrade part numbers or this info. TCS is great site but search or even their categories doesnt pull up everything they have all the time. u have to have the part#. thanks again! oh, do you have to thread these steering pipe pieces u listed above? it looks like it. ive never done that. Last edited by neuro242; 08-29-2009 at 12:48 PM. |
08-29-2009, 12:46 PM | #15 |
Quarry Creeper Join Date: Aug 2009 Location: Palo Alto, Bay Area
Was looking for them the steering links too the other day. Found em at tower hobbies: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSAR7 |
08-29-2009, 01:06 PM | #16 |
yeah those are threaded but cant tell about the ones at TCS. do u have to get a threader?
08-29-2009, 01:25 PM | #17 |
The axial ones are already threaded 3mm threads
08-29-2009, 01:29 PM | #18 |
This is the only part that is Axial but doesn't say it's threaded: http://www.tcscrawlers.com/Axial-Rac...2-p-16692.html The others specify threaded but it seems TCS only carries it in orange, not green. Ill just see and get a tap and die if i need it. |
08-29-2009, 01:30 PM | #19 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
just go to a vender and get a derlin one
08-29-2009, 01:40 PM | #20 |
All of the part numbers I listed are green and they are all threaded, they are the same ones from the kit.
