08-29-2009, 04:56 PM | #1 |
Pebble Pounder Join Date: Apr 2006 Location: Newton
| Which motor for me
My Ax-10 currently runs an Novak 55t, people are telling me that my troubles are coming from an old motor that needs replacing. So, I thought, what the heck. I'll just replace it and see. I never like buying the same part twice, because I think there is always room for upgrades. My question is what is a good motor for my AX-10? stock spur with 12t pinion HB Rovers 5.5 oz in each front and 4.25 oz on each rear. 1500 6 cell split pack Rooster ESC Trying to stay semi cheap, but get something good. Will be thankful for any help on this topic. |
08-29-2009, 05:01 PM | #2 |
To stay cheap and good... toughy. I guess the V11 Integy motor. 35 turn or 45 turn, though they have a 55 if you like your wheelspeed as it is now. http://holmeshobbies.com/product.php...&cat=17&page=1 |
08-29-2009, 05:23 PM | #3 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
What problems are they? You probably just need to clean out the motor.
08-29-2009, 11:46 PM | #4 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
| Yeah I would clean it up, I usually hook mine up to a single subC battery, dunk it in water a few times, then electric motor spray, then oil the bearings. The comm may need to be cut, or the brushes could be worn out.
08-30-2009, 09:33 AM | #5 | |
Quarry Creeper Join Date: Jan 2009 Location: North Wales, UK.
The Novak 55 sucks - it's magnets are very weak. A bit better is the Integy 55 Lathe motor or better again the V11 as EeePee suggested. | |
08-30-2009, 03:30 PM | #6 |
what's the difference between 55s and 55t? will either work for me?
08-30-2009, 04:05 PM | #7 |
They're the same. I think by 55s they mean 55's as in plural, 55t just means 55 turns, the higher the turn the slower the motor so a 65t is even slower.
08-30-2009, 04:14 PM | #8 |
thanks alot, i know now what i must do. lol |
