08-30-2009, 04:49 PM | #1 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
| Slash type slipper mod!
So I dont know if Im the only one but I seem to keep chewing up my spur gears and those crappy spurs they sell at the hobby shops just dont cut it. They are too flimsy and too soft. I finally finished off my last spur today at a GTG and was desperate to get my truck up and running again. Then the light bulb went off. What parts do ALL hobby shops carry. Traxxas. Started looking at the slash type slipper and it looked to mount similar to the stock axial slipper. Bought the stuff and vuala! It all fit perfectly. Only one thing needed to be modded. The hole in the input shaft that holds the slipper plate needs to be drilled out to the size of the stock traxxas pin. It was a 5/64 bit if my memory serves me right. Ran the truck today wit NO problems at all. everything clears and the slipper holds fantasticly. Ill hopefully have pics up by tomorrow. |
08-31-2009, 04:26 PM | #2 |
Got the pics and everything is pretty self explanitory. The slash spur gear is holding up extremely well as I had figured it would. If a slipper will hold with a truck like the slash hitting the ground at full speed with a castle brushless system on 3s then it should hold up good in a crawler. The slipper assembly ready for the truck The stock axial slipper pin The stock traxxas pin after the shaft was drilled and the pin inserted. Another pic of the tranny input with the traxxas pin inserted. All clear on the back side. All clear up front. Its that easy. What ya guys think! |
08-31-2009, 04:29 PM | #3 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
Cool deal if you want to run a slipper |
08-31-2009, 04:29 PM | #4 |
The Traxxas slipper and spur gear is the worst design I have ever used. Good luck. |
08-31-2009, 04:51 PM | #5 |
Quarry Creeper Join Date: Aug 2009 Location: Palo Alto, Bay Area
09-01-2009, 05:49 AM | #6 |
this setup actually works really well, and yes I do wanna run a slipper because I just put in the outrunner in the pic and its a little bit of a learning curve to figure out what the capabilites of the motor are. The whole reason I wanted to do this is because all of the spur gears any of the hobby shops have (at least around here) are those kimbroh ones. They are flimsy, soft, and the second there is ANY torque put on them the teeth fold right over. |
09-02-2009, 06:49 AM | #7 |
Pebble Pounder Join Date: Aug 2009 Location: San Jo
Hey slowguy. thats a great idea... way to use the noggin. i think traxxas is only good for their plastic parts. not to use on their own rc's but on other ones. is there any way that you remember the traxxas part# for that slipper? i dont personally have an ax10,but my brother does and i will pass down the helpful info
09-02-2009, 08:26 AM | #8 |
Newbie Join Date: Jan 2008 Location: Rolla, MO
Im running a traxxas spur gear on my ax10, its been holding up really well. I think it might be a stampede or rustler gear, not the revo spec like the one your running. How hard was it to drill a hole through that shaft?
09-02-2009, 09:13 AM | #9 |
Rock Stacker Join Date: Mar 2008 Location: Milwaukee, WI
Good idea. Running the AX at races sponsored by Traxxas puts a damper on getting replacement parts for it. Often I have to rig up a Traxxas part if I break something. But I never thought of a slipper. How tight did you tighten the spring? |
09-02-2009, 02:28 PM | #10 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
09-02-2009, 03:02 PM | #11 |
Sicario666- Im sorry I dont remember. I just went up and asked for the parts I needed to assemble the slash slipper. There was one bag with the back plate and pin and slipper ring and another bag with the slipper pads and pad holder, then I bought an 86t spur and the bearing that fit it. (same as stock traxxas bearing) If you look on the site they have the parts legends with the part numbers labeled. Azngtboi88- It drilled right through, no problems! ihcj9- One of the bags came with the spring and nut. I just slid it on and tightened it down. It all fit on perfect. |
09-02-2009, 03:21 PM | #12 |
09-02-2009, 03:54 PM | #13 |
It was a 5/64 drill bit.
09-02-2009, 04:02 PM | #14 |
lol...I hated the spur on my Slash so much I modded an Axial slipper/spur to fit. btw: I have never, ever, ever tore up a Kimbrough. I've ground rocks through them without incident. For three years the same Kimbrough spur has been in my sons B4. I also run one in my Slash and both my super and 2.2 crawlers. On my 2.2 its the only thing that hasn't gone bye-bye in the drivetrain. |
09-02-2009, 07:33 PM | #15 |
Lol. Exact opposites. Are you getting the shiny black ones? Those are the only ones anyone carries and thats what I always tear up. The teeth dont shear off, the gear deflects and the teeth all fold over. Even if Id set my mesh a little tighter. I always set my mesh a wee tighter than what you get with the old paper trick. |
09-02-2009, 08:41 PM | #16 |
Quarry Creeper Join Date: Jul 2008 Location: peoria
this is much better and 22 dollars cheaper than the axial slipper thanks got mine for 8 dollars http://cgi.ebay.com/NEW-TRAXXAS-SLAS...l_Parts_Access |
09-03-2009, 06:06 AM | #17 |
Nice link. Yup thats exactly what I put in my truck in this thread.
09-03-2009, 09:18 AM | #18 | |
If you're really having that much trouble with the spurs, swap over to 32p. Much harder to destroy. My main gripe with the Slash spurs is that they are too easy to deform under load. If I can squish them with my bare handed kung-foo grip action, they aren't stong enough to take the punishment my truck will bring them. Last edited by Duuuuuuuude; 09-03-2009 at 09:23 AM. | |
09-03-2009, 12:17 PM | #19 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
I have also been using the Kimbrough gears. I have yet to kill one, as long as my mesh is good. I have rounded off most other gears in the 48 pitch size. 84t instead of 87t because it hits the MIP driveshaft.
09-03-2009, 04:08 PM | #20 |
Well I have had no issuse thus far but I am gonna go out tonight and put the truck through its paces and find out what the limits of this is. Ill post up later with my findings. |
