09-20-2009, 02:40 PM | #1 |
Newbie Join Date: Sep 2008 Location: Jupiter FL
| ax10 help
i have a ax10 kit and just ran it for the first time and the drive shafts keep coming off at the trans output shaft front and rear. i have used blue thread lock and the red and still cant fix them. and i now have play in the front wheels i think that i need to get the hop up ones? also my trans has play in it to i can move the big gear up and down this i have no clue as to what to do please help
09-20-2009, 04:45 PM | #2 |
| bump
i see that some of you have had some of the issues that i have i just want to get back on the rocks
09-20-2009, 05:48 PM | #3 |
How long did you let the thread lock set up before you ran it? You should let it sit over night. Also, before you put it back together make sure your threads on the u-joints and the grums are clean before you put the thread lock on.
09-20-2009, 06:21 PM | #4 |
Pebble Pounder Join Date: Sep 2008 Location: cny
you need to use two set screws on your shafts one on each side along w/ the loctite,had the same problem w/ mine till i got my mip's,as for the tranny slop goes make sure you didn't leave nothing out bearing in the wrong spot, not there at all, sounds lik assembly error.check your manual and rebuild your tranny,make sure you got everything.the wheels mine seem to hav a little bit of play but nothing major. ? for ya do you have the flange pipe parts installed in the knuckles? that might cause some slop but don't know for sure.
Last edited by bigheadandmoose; 09-20-2009 at 06:24 PM. Reason: forgot to add something |
09-20-2009, 08:32 PM | #5 |
| ok
thanks im going rebuild the trans now and as for the wheels ill look in to that ok
