10-15-2009, 01:22 PM | #1 |
Newbie Join Date: Sep 2008 Location: Upper Deerfield
| suspension issue I think???
I built the axial kit over a year ago and lately have noticed a problem with it lifting the inside front tire on an uphill turn. More specifically if you are going cross hill and turn up hill it lifts the high side tire sometimes to the point of causing it to turn over. I'm not talking extreme hill angles. I'm from south jersey and most of our crawling is fairly flat. Any suggestions would be appreciated. I've rebuilt the front axle, the front shocks and added more weight to the front tires nothing seems to help.
10-15-2009, 01:47 PM | #2 |
It's called torque twist. The side that lifts,take the opposite side rear shock....if the left front is lifting,work on the right rear. Try either thicker oil or stiffer springs. Could also try different pistons in the shocks to adjust the valving. That'll help allot. Adding a little anti squat will help as well. |
