Thread: BTA steering kits / reviews
Old 03-24-2010, 11:17 AM   #1
Default BTA steering kits / reviews
i'm considering a BTA steering setup. i've heard of the RPP Hobby's LD Racing BTA Kit being decent. but i've not found any actual reviews or pictures of it installed.
does anyone have actual pictures or experience in using this kit?
wicked4x4 is offline   Reply With Quote
Old 03-24-2010, 12:15 PM   #2
Here is a picture of my setup - not finished and tested. I'm using Vanquish knuckles, Axial c's and Axial CVD.
stianl is offline   Reply With Quote
Old 03-24-2010, 12:57 PM   #3
which knuckles did you go with? the high clearance or the zero ackermann's?
and thank you for posting the pic
Old 03-24-2010, 02:33 PM   #4
It's the high clearence knuckles
Old 03-24-2010, 03:14 PM   #5
i just installed by LD racing bta, its nice and cheap
im running axial alum knucks i just grinded down the outside screw hole
has plenty of clearance with the included spacers
i did have to grind down the corner where the servo is at on the inside for clearance but nothing major
the only thing that kinda bugs me and its that way with the other bta kits is the wheel wobble, what ive notice with mine as well is that the screws holding the tie rod in with the spacers cant be over tight or the servo with be in overdrive to push the rod
it works great and its cheap
liverkiller1 is offline   Reply With Quote
Old 03-24-2010, 06:37 PM   #6
abadk9420's Avatar
I would definitely go with the VP Hi-Steer knuckles, it will give you more steering then cutting the knuckles and using the spacers, that is what I did after trying it with the Axial Aluminum knuckles first.
abadk9420 is offline   Reply With Quote
Old 03-24-2010, 08:18 PM   #7
ill have to give those i try got them on order now my setup is about the same as yours minus the vp knucks
Old 03-24-2010, 08:39 PM   #8
abadk9420's Avatar
You will really like the VP knuckles, it makes a huge difference, gets rid of the spacers and you will no longer have the shock/lower link mount to worry about because the hi-steer arm sits above all of it...
Old 03-24-2010, 09:03 PM   #9
I have the Axial BTA. If you want to see it I live in Mira Mesa. Matt
SDheavymetal is offline   Reply With Quote
Old 03-24-2010, 09:16 PM   #10
I'd like to see some pics of your axial bta set up. I have one that I just took off because it's giving me nothing but problems. I'm about to re do it and if you got yours set up and you're happy with it then maybe I can use yours as a reference when I do mine again.
James003 is offline   Reply With Quote
Old 03-24-2010, 10:04 PM   #11
hey with the vp knucks is there still that wheel slop/wobble?
Old 03-24-2010, 10:12 PM   #12
abadk9420's Avatar
Can't say I have a problem with wobble or slop on mine, I am currently using stub shafts and axles because i have been blowing up CVD's, mine tire and wheels only move slightly from side to side but I thinks that is more just the tire not being 100% true, not caused by the steering.
Old 03-25-2010, 01:15 AM   #13
ya im running the axial hd cvd with gunnars pins these pins have lasted longer then the stocks for sure, right now i got dh comps with a 350 offset with is not enough, but my slws with 600 should solve the front ha, ya i hope once the vp knucks get here itll solve the slop
Old 03-25-2010, 09:30 AM   #14
better yet, maybe we could meet at canyonside next week in an evening? it's in between us, i'm in poway. plus rchuffer was mentioning getting together there as well.
thanks for the info and tips everyone.
Old 03-25-2010, 10:15 AM   #15
I just pulled the original v2 (ldrp/jetdesigns) kit off my axles for a "tuneup". After 2yrs and I don't know how many batteries and 3 servos, it showed very little wear around the holes in the tie rod, the spacers where perfect. I drilled out the holes, inserted some bushings from axial and put it all back together with a jr 8711.
Ldrp took my design, cleaned it up a bit with some suggestions from me and in my opinion, now has the best bta on the market.
jetboat is offline   Reply With Quote
Old 03-25-2010, 10:00 PM   #16
Here are the pictures of the BTA.
