10-19-2009, 06:06 PM | #1 |
Rock Stacker Join Date: Feb 2009 Location: fond du lac
| integy chassis
anyone use one of theses http://www3.towerhobbies.com/cgi-bin...?&I=LXTYC0&P=7 |
10-19-2009, 06:08 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Reno, NV
its just like the stock ax10 chassis but you have a little bit more options on mounting things otherwise it just looks better. all the same |
10-19-2009, 06:18 PM | #3 |
so i am just better off drilling more hole in my stock one
10-19-2009, 08:38 PM | #4 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
i have that chassis, only because i bought my truck used with it. they are alright, more adjustability. to make use of the shock adjustments you need longer shocks or you lose all ground clearance, and to use the upper link mount adjustments you need longer links or your pinion points into the ground. if your looking for some bling and a bit more adjustments, it does that well. edit: i just realized mine is the +30mm xl integy chassis, that would explain why nothing seems to work correctly with my truck. |
10-19-2009, 09:02 PM | #5 |
Your better off in the long run to actually upgrade rather than buy a cheap rip off. I'd highly recommend the Bender Customs SWX Chassis Kit It's been proven many times over,it flat out works. |
10-19-2009, 09:18 PM | #6 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
if your loking for a good cheep chasis get a widow im loven mine an there 40 bucks
10-20-2009, 03:39 PM | #7 |
iam lookin for just a simple back yard basher so i don't want to spend a ton i can get the integey for 20 bucks. this truck will never be a comp rig
10-20-2009, 03:47 PM | #8 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
| I'd save that $20 if I were you. The integy chassis doesn't improve anything over the stocker that you can't do with a drill and a can of spray paint.
10-20-2009, 03:49 PM | #9 |
ill keep looking then
10-20-2009, 03:49 PM | #10 |
Newbie Join Date: Oct 2009 Location: SF Valley
10-20-2009, 03:53 PM | #11 |
4 bucks cant gowrong i love mine
10-21-2009, 12:20 AM | #12 |
Newbie Join Date: Mar 2009 Location: flint
trust me out of expierence, almost all integy parts are cast alum, not cnc or plate..... this equals VERY easy to break. found this out on my first nitro truck, and trust me it might go slow, but your crawler takes a lot more abusre than it seems like
10-21-2009, 12:23 AM | #13 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
| X2..Integy doesn't have the best of quality.
10-21-2009, 02:15 PM | #14 |
Newbie Join Date: Nov 2008 Location: Marysville
Integy aluminum is aweful. Just good for shelf queens.
10-21-2009, 04:49 PM | #15 |
the only integey parts i have are the steering have not had any probs with so i thought to give it a try but i will be looking for something else now
10-24-2009, 07:14 PM | #16 |
Newbie Join Date: Oct 2009 Location: San Francisco
i used that chassis for a few weeks, the body mounts and the upper link mounts bend, but its really soft so u can bend it right back. I now have a Scale'r frame and alot less articulation.
