10-21-2009, 12:54 PM | #1 |
Newbie Join Date: Oct 2009 Location: Garden Valley
| slipper clutch
im new to the rc rock crawlin and i bought the rtc scorpion and the slipper clutch isnt engaging like its supposed to my drive gears keep grinding, ive tried adjusting the spring tension but that isnt working. any advice?
10-21-2009, 12:56 PM | #2 |
Newbie Join Date: Jun 2008 Location: Greenville
Tighten the nut/spring all the way down. Drive it and upgrade anything that breaks. Yes, I'm serious. No I'm not trying to be an asshole. |
10-21-2009, 01:37 PM | #3 |
Pebble Pounder Join Date: Nov 2008 Location: Marysville, WA
| X2...but I would suggest you splurge on the hardened steel outdrive gear as well. I have a slipper clutch on mine and it's tightened down as far as it will go, with the upgraded outdrive gear..works like a champ |
10-21-2009, 02:48 PM | #4 |
ok thanks!
10-21-2009, 03:17 PM | #5 |
any online shops you would recommend?
10-21-2009, 03:31 PM | #6 |
Check the vendor's section on here. I'm still running stock tranny gears (2 years) though so my advice is wheel it until it breaks. |
10-21-2009, 04:49 PM | #7 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
i like the slipper... tighten it down and a 1/4 to 1/2 turn out to tune. never had a grinding issue... have you checked your pinion /spur settings ?
10-21-2009, 09:08 PM | #8 |
| You have no reason to "like" the slipper clutch on a rock crawler..it will be the reason you will have to rescue your truck by hand when you get the tires bound up on the rocks...the fact of the matter is, that slipper clutch was intended for the "Racer" portion of the RTC Rock Racer...If you are only Crawling Rocks, then you have to tighten that slipper clutch all the way down, period. I know this from experience, cause my slipper clutch wasn't allowing me over a certian spot on the rocks, then when I tightened it all the way down, it crawled the same spot fine, some tire binding, but it handled it fine...had to hand recue that spot with the loosened slipper....Main Point, tighten the slipper down, or rebuild your tranny to allow for elimination of the slipper clutch altogether... |
10-21-2009, 09:14 PM | #9 |
i like mine to just barely slip on a full batt. at any given throttle
10-21-2009, 09:15 PM | #10 |
| meant to say that I agree with this guy, leave the stock outdrive gear until it breaks. I don't know how much it can actually handle cause I didn't break mine. I just bought the hardened steel one because I had a gift card to my LHS and that was one of the things I picked up with it. It's pretty spendy, so it's a part you probably could wait to change out depending on your crawler budget.
10-22-2009, 06:31 PM | #11 |
ya i fixed the issue i just moved the motor closer so the gears meshed better. thank you guys.
10-22-2009, 07:12 PM | #12 | |
its all a matter of choice... what works for me may not work for you Last edited by DeweyCJ5; 10-22-2009 at 07:24 PM. | |
10-22-2009, 08:35 PM | #13 | |
10-22-2009, 08:37 PM | #14 |
and...I stand by my advice to eliminate the slipper altogether....it's worthless...tune yer tone...
10-22-2009, 11:42 PM | #15 |
lol good to see that your experence is showing....now back to topic |
