11-03-2009, 10:08 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: south jersey
| need some shock advice
i recently got a axial kit and i changed the chassis right away to a bastard jr tuber chassis my question is what kind of shock should i run and what size should i go bigger in the fron then the back or the same size any help would be great thanks
11-03-2009, 10:43 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
i dont run a tuber, however on my truck i run losi 4" crawler shocks and they work great
11-03-2009, 11:22 PM | #3 |
yeh thats what i got now but my belly is way to high im on my lowest setting no and i still have a belly clearance of almost 5 inches way to high?
11-04-2009, 12:13 AM | #4 |
Rock Crawler Join Date: Mar 2008 Location: ...in your meter box...
I'm pretty sure the bastard is best set up with droop suspension. Just type in bastard jr. in the search option. Then you can see what others have done and get some ideas from there. search button = what you wanna know |
11-04-2009, 02:50 PM | #5 |
Rock Stacker Join Date: May 2009 Location: Belo Horizonte -Brazil
hi folks.. I need to replace my AX10 stock ( leaking) shocks . these shock are good choice? http://cgi.ebay.com/Aluminum-Threade...item1c0d870a25 thanks |
11-05-2009, 09:07 PM | #6 |
ok thanks guys
