11-07-2009, 08:19 AM | #1 |
Rock Stacker Join Date: Aug 2004 Location: Under a Rock
| 3 or 4 link setups ?
I see alot of people going to a 4 link setup..... I would if I had any probs with the stock 3 link deal, the rig flex's more than enough as is. Is it for the torque twist ? More flex ? Smoother flex ? Please explain why you went from 3 to 4 link setups ! For now I like the 3 link.. |
11-07-2009, 08:39 AM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
swapping top a 4 link will give you a smoother more predicable suspention movement, its stronger then the 3 link, since the forces are applied to 2 ball ends rather then one, it helps eliminate TT. It doesnt nessisarily give you more flex just makes the flex you have better, to much flex isnt always a good thing any way
11-07-2009, 08:46 AM | #3 |
Rock Stacker Join Date: Mar 2009 Location: UPSTATE
+1 for the TT helped mine a ton
11-07-2009, 10:34 AM | #4 |
Rock Stacker Join Date: Feb 2009 Location: Oslo, Norway
I would say 4-link reduces flex, and as mentioned before, it makes the suspension more predictible
11-07-2009, 10:52 AM | #5 |
Rock Crawler Join Date: Dec 2005 Location: North Vancouver
I went for it because it's stronger and the placebo effect of reducing torque twist Eventually you will break the y connector or the ball will get sloppy and you'll get alot of axle wrap.
11-07-2009, 03:21 PM | #6 |
Rock Stacker Join Date: Apr 2008 Location: Fairbanks
I went with a 3-Link in fromt and 4-Link in the rear.
11-07-2009, 10:14 PM | #7 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
I went 4-link rear and I am going 4-link front. 3-Link is a bit un-predictable and I found the car getting "stuck" way to much by over articulating... putting to much strain on the shock caps (ya can we say I popped a few of them ). I am working on some custom PDF's for plates... should get em out soon |
11-08-2009, 04:39 PM | #8 |
Newbie Join Date: Jan 2009 Location: milton
Im going with a 4 link in back and 3 link in front / any suggestions for front 4 link
11-08-2009, 06:14 PM | #9 |
I see how a 4 link would make it stronger, I will try and work out a better mounting point for a stronger 3 link and also replace the stock ball end with a TRAXXAS unit...
11-08-2009, 07:49 PM | #10 |
RCC Addict Join Date: Feb 2006 Location: ccxc
i just switched to 4 link front (rear is already) because I need to run a battery plate..........no real noticable difference for me.
