12-20-2009, 07:03 PM | #1 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| Upgrade for the axial spur HUB ?
Axial transmission spur HUB, I cant believe how poorly this thing is made with cheap plastic. Is there something stronger that is an upgrade other than making one ? |
12-20-2009, 07:18 PM | #2 |
I guess this is the only alternative http://www.hot-racing.com/index.cgi?...=SCP1505&c=420 something worth having in the tool box when yours blows |
12-20-2009, 08:04 PM | #3 |
Pebble Pounder Join Date: May 2008 Location: Two Harbors, MN
I switched to Axial's slipper clutch set-up.
12-20-2009, 08:13 PM | #4 |
Rock Crawler Join Date: Jun 2009 Location: summertown
ive been using the factory adaptor for about 4 months now and have yet to have a problem (if it aint broke don't fix it.) you'll end up with more expensive problems, and its always better to have a cheap weak link!
12-20-2009, 10:28 PM | #5 |
I'm still running the original spur/assembly from when I bought my truck new 8 months ago...never had a problem. Even with a 5t puller and no slipper its holding up just fine. A metal spur would be a big no-no IMO. Plastic is a cheap weak link, much better than an expensive weak link.
12-20-2009, 11:21 PM | #6 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
There is this one. http://www.venom-group.com/itemdesc.asp?ic=VEN-4017 |
12-20-2009, 11:33 PM | #7 |
Quarry Creeper Join Date: May 2008 Location: looking for sponsors
i had the same problem so i went with hr and i have no regrets its a nice item and does its job |
12-21-2009, 06:15 AM | #8 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
I found this mod and it works amazing. I havent had a single stripped gear or anything since. Slash type slipper mod! |
12-21-2009, 12:54 PM | #9 |
Thanks slowguy, that looks pretty good, I have a aluminum hub that Icould use but just like that thread I would have to drill a hole for the pin and I am not to confident on it's durability. YEa the stock plastic should work for a long time for those light 2.2's I guess I should actually say it has held up very well in a 10 lb. Super I agree with a weak link system. the slipper did not hold enough and I didn't spend any time fabricating a tougher one Last edited by toy4crawlin; 12-21-2009 at 01:04 PM. |
12-21-2009, 01:00 PM | #10 | ||
You don't put a pick-up truck transmission in a semi and expect it to hold up. It's a 1/10th scale transmission. | ||
12-21-2009, 01:14 PM | #11 | |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
But yes, for the o.p., it's probably it bit on the weak side for a super. | |
12-21-2009, 02:44 PM | #12 |
| I know , my bad, i was frustrated. when I took it off it look like only a small portion of the adapter was slotted and not the whole hole.
12-21-2009, 06:18 PM | #13 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
what gears you running in that thing? I have stripped my aluminum tranny gears, but never stripped one for those.
12-21-2009, 11:04 PM | #14 |
Pebble Pounder Join Date: Dec 2009 Location: Magalia, CA
I changed my spur gear out with a 90t its plastic also but my 12t pinion gear is aluminum...no problems with either....
