12-24-2009, 07:48 AM | #1 |
Rock Stacker Join Date: Oct 2009 Location: canada
| AX10 spur gear
I bought a ax-10 trany for my scale bronco only to realise it came without the spur gear. After looking things up I realised I was missing the following items. -spur gear -gear adapter -spring -2x washer -lock nut I'm I missing anything and would it be worth getting the slipper clutch. I'm running a stock 27t axial motor with pede trany and tlt axles. |
12-24-2009, 07:56 AM | #2 |
Rock Crawler Join Date: Sep 2009 Location: minnesota
Some people swear by the slipper clutch while others swear it hinders them. I think it is all personal preference and how you like to drive. A slipper clutch can reduce driveline breakage, but it can also hinder you if it slips at a point where you just need a little bit more to get over an obstacle. It also depends alot on your driving style, but in the end it is preference. hope that helps. |
12-24-2009, 08:44 AM | #3 |
Rock Stacker Join Date: Nov 2008 Location: sioux city
| gear
I Have ran both and they both worked for me the slipper and w/out the slipper clutch.
12-24-2009, 08:46 AM | #4 |
Yeah it does help. I don't think I'm one to break much stuff but then again my truck isn't even finished yet. Guess i'll when it gets it's first miles in, but I don't think I'll be needing a clutch.
12-24-2009, 02:02 PM | #5 |
Spring? I don't remember the non-slipper trans having a spring. I prefer to run without a slipper clutch. Common sense will tell you when you are stuck STUCK and won't be able to power out. Plus you can't really "power out" with a slipper, as it will slip. Then again we all fall victim to the occasional "bone headed moves" and you could always play on the side of caution. |
12-24-2009, 03:26 PM | #6 |
Pebble Pounder Join Date: Dec 2009 Location: scotts valley
I run the slipper and haven't had a problem. I run it pretty tight.
12-24-2009, 11:13 PM | #7 | |
Rock Crawler Join Date: Jun 2007 Location: Arlington
Don't use a slipper, and don't be stupid. If it looks like the tires are about to re-tread themselves, they're about to strip gears. | |
12-25-2009, 12:56 AM | #8 |
12-26-2009, 08:35 AM | #9 | |
You're right no spring there is a spacer behind the spur gear though. I must have been looking at the rtr pdf by mistake. Check out pg 16 http://www.axialracing.com/ftp/pdfs/AX90001-I002.pdf | |
12-26-2009, 03:52 PM | #10 |
Quarry Creeper Join Date: Nov 2009 Location: East Greenville
do they make them in metal?
12-26-2009, 04:42 PM | #11 |
i'd like part no AX8009 (the non slipper spur adapter) from that page in aluminium
12-27-2009, 09:23 AM | #12 | ||
http://cgi.ebay.ca/Axial-AX10-Scorpi...item53de6c0721 http://cgi.ebay.ca/Axial-AX10-Scorpi...item53de6c022a Would a spur gear from pede trany fit on the axial trany? | ||
12-27-2009, 11:31 AM | #13 |
Rock Stacker Join Date: Jun 2009 Location: Canada
I'd stay away from a metal spur. Just my opinion of course, but in my experience it's always nice to have a week spot some place in the line of power transfer. Spur gears are cheap, and if you have the gear mesh right you should rarely, if ever, strip a spur. This is the reason I run pede drive shafts instead of steel ones as well, saves on tranny and diff gears. |
04-27-2011, 11:29 AM | #14 |
Quarry Creeper Join Date: Jan 2011 Location: armstrong
keep running the plastic spur and go slipper less my rig is step up with out a slipper and have yet to have a problem had it bound up a couple of times prtty hard
04-28-2011, 07:37 AM | #15 |
I've nevr ran the slipper, I have one but never used it. It's just extra weight in my book. |
