12-31-2009, 10:23 AM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Fraggle Rock
| C hub help.
As I broke the plastic c hub on the front axil that comes with the AX10 Scorpion. What would be a good replacement for this? Thanks |
12-31-2009, 10:24 AM | #2 |
Newbie Join Date: Oct 2009 Location: Anchorage
Several stock ones. Aluminum will just make the next part break.
12-31-2009, 10:30 AM | #3 |
12-31-2009, 10:44 AM | #4 |
Rock Stacker Join Date: Nov 2009 Location: Newberg
im with them aluminum will just make the next part break unless full billet axles are your thing
12-31-2009, 11:28 AM | #5 |
Quarry Creeper Join Date: Jun 2009 Location: Winchester
Go with the aluminum, yes, it may make the axle case break, but the aluminum C's are much nicer, especially if you get ones that are clockable.
12-31-2009, 11:50 AM | #6 |
Aluminum C's are by far the better choice. Yes it removes a weak link and therefore something else will break instead possibly. However it will still be stronger than before or else that part would have broke first. I have crawled a lot with AX-10 axles and only seen a couple cases break after a lot of hard abuse. Axial brand C's are great, but all of them are pretty close to equal. |
12-31-2009, 11:59 AM | #7 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
After going thru tons of stock plastic ones I switched to Alum and WOW less slop and strong been beatin mine up or month with no breakage
