01-01-2010, 04:10 PM | #1 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
| Vanquish Products Incision Build Thread
Hey guys. Post your VP Incision builds here. Here is my VP Incision Shafty build Started with some Felsenfest lockers, hardened ring and pinions, and Felsenfest V5 knuckles and Felsenfest CVDs - THANKS CHRISTIAN I decided to use CKRC C-Hubs instead of Axial because they are 1.5mm wider for more steering clearance. Last edited by Rig Rocker; 01-09-2010 at 05:09 AM. |
01-01-2010, 04:22 PM | #2 |
Decided on CKRC 45T Twista brushed motor - Had great luck with them http://www.ckrccrawlers.com/shop/ind...oducts_id=2222 |
01-01-2010, 04:24 PM | #3 |
Hateraide Join Date: Dec 2008 Location: Mission BC
Should be a good build you already got some sick parts |
01-01-2010, 04:28 PM | #4 |
Trusty Tekin FXR ESC and Castle Creations BEC set at 6v
01-01-2010, 04:29 PM | #5 |
01-01-2010, 04:32 PM | #6 |
VP Parts used: VP Incision Pro Chassis VP Hurtz Dig w/Hitec 225mg mini servo VP Front and rear 4 link plates - cut down for clearance VP shock risers Last edited by Rig Rocker; 01-01-2010 at 04:49 PM. |
01-01-2010, 04:34 PM | #7 |
Axial 72-103 comp shocks 80wt front and rear |
01-01-2010, 04:43 PM | #8 |
My Absolute FAVORITE parts - 1" Mayhem Double Comp Phatty And Ultimate comps pictured because they look so sweet - running DCP's though THANKS DAN Can't wait for the engraved 16 hole rings so I can advertise for you Last edited by Rig Rocker; 01-01-2010 at 05:58 PM. |
01-01-2010, 04:48 PM | #9 |
MIP / Thundertech Axles Homemade Ft links 1/4" aluminum rod CKRC 30% rear 1/4" aluminum links lengths are eye to eye Upper Ft - 91.5mm Upper Rr - 90mm Lower Ft - 125mm Lower Rr - 126mm |
01-01-2010, 04:59 PM | #10 |
Steering servo is Hitec HS-7955TG Steering link is 154mm eye to eye Drag link is 53mm eye to eye |
01-01-2010, 05:00 PM | #11 |
Radio system is Spektrum DX3R
01-01-2010, 05:06 PM | #12 |
Tires are white HB Rovers Foams are NWTT Rockhammer Hybrid #8 narrowed 1/2 inch |
01-01-2010, 05:11 PM | #13 |
Completed chassis
01-01-2010, 05:12 PM | #14 |
And my Favorite body Beat-up Proline Chevy C-10 Last edited by Rig Rocker; 01-01-2010 at 05:14 PM. |
01-01-2010, 06:05 PM | #15 |
I'll be testing it tomorrow up in the Santa Cruz mountains and will post action pics. I will also be adding the new videos to my youtube page: http://www.youtube.com/user/benzlick Hope you enjoy and hope the info helps anyone else thinking of or currently building an incision chassis rig. Starting a Mayhem LS2.0 build too so keep an eye out for that. and......... HAPPY NEW YEAR!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
01-01-2010, 06:07 PM | #16 |
Rock Crawler Join Date: Jun 2009 Location: Middleburg
What end links are you running on your uppers and lowers. I need to remake my links for mine.
01-01-2010, 06:14 PM | #17 |
| I am using stock axial short ends AX80005 #1. I always use them when possible because they are plentiful and they will give, and stretch in an extreme fall instead of breaking. They need to be replaced after they have stretched though, or they will break
01-04-2010, 02:28 AM | #18 |
Wansn't able to go to the mountains this weekend. Got called into work. I'll try and get some action pics this week though. Crawls really nice on my home course "Hell Mountain"
01-04-2010, 02:48 AM | #19 |
RCC Addict Join Date: Jan 2005 Location: Germany north
is it possible to mount the front shocks without the green spacers ? it will give you a little more steering and hurry up with the video |
01-04-2010, 10:08 PM | #20 | |
I've been on call and working a lot, but I think I'll have time tomorrow to take it to the local indoor course. Then I can make some more videos! | |
