01-11-2010, 06:03 PM | #1 |
Newbie Join Date: Dec 2009 Location: manchester
| ax-10 keeps blowing driveshafts off
So i have only had my ax-10 for a few days and have only drivin it around for about an hour but i have blown the driveshafts off the tranny like 10 time i have tightened the little hex till it is very tight but it will still loosen up. Front and rear are doing it so i need to upgrade to Hd ones? I also have a hobbywing esc with a brushless motor....... thats what it came with so i this to much power for the stock stuff i am planning to buy a diff motor and esc cause this one is more for like a rock racer i think the ax-10 moves right along with this. any help would be great! |
01-11-2010, 06:06 PM | #2 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
locktite |
01-11-2010, 06:12 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
01-11-2010, 06:13 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Tehachapi, Ca
| lock tite
use some lock tite on the little screws i was having the same prob with mine when i first got it i use the blue gel stuff its alot easier to apply then the other stuff |
01-11-2010, 06:13 PM | #5 |
Thats what i thought about doing but didn't know if there was something else... I'll grab some from my tool box at work tomorrow!!! |
01-11-2010, 06:16 PM | #6 |
01-11-2010, 08:57 PM | #7 |
Newbie Join Date: Oct 2009 Location: HighTop
Loctite anything that is metal to metal that doesn't have a lock nut. i.e. yokes, wheels, etc...
01-11-2010, 08:59 PM | #8 |
Oh by the way, I have had better luck with the stock Shafts than I have the Integy. If you are going to buy aftermarket go MIP. Worth the extra change IMHO!
01-12-2010, 07:41 AM | #9 |
Newbie Join Date: Nov 2009 Location: irvine
Not sure why but I turned my shafts around and they stopped coming off |
01-12-2010, 01:49 PM | #10 |
Newbie Join Date: May 2009 Location: Reno, NV
I used a small drill bit and made a small hole for the screws to sit in.
01-12-2010, 05:47 PM | #11 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
locktite and MIPS
