01-19-2010, 06:30 PM | #1 |
Newbie Join Date: Dec 2009 Location: San Jose
| 27t/55t motor
Has anyone tries 27t motor? Does it runs faster than 55t? Does it drains the battery? Do I need higher than 7.2v battery?
01-19-2010, 06:39 PM | #2 |
Pebble Pounder Join Date: Mar 2009 Location: Grande Prairie A.B
| The 27t will run way faster than the 55t. It will drain your batery faster. If you have the 55t i would run that, it has more torque and your batery will last longer but if you want speed then run the 27t
01-19-2010, 06:44 PM | #3 |
RCC Addict Join Date: Nov 2005 Location: Kansas
I ran a 27t in a TLT rig I had a few years ago... it was STUPID fast... too fast to do any real crawlin at least...
01-19-2010, 06:51 PM | #4 |
Rock Stacker Join Date: Dec 2009 Location: midland
if you're just going to do crawling with it, definatly go with the 55t. but if you want some speed at the sacrifice of torque and runtime go with the 27t. my crawlers i run a 55t and my scalers i run a 27t because i like the wheelspeed for muddin antics.
01-19-2010, 07:32 PM | #5 |
Newbie Join Date: Oct 2009 Location: Malaysia
Yup, 27t run faster/low torque than 55t motor. i have run 55t and 20t stinger in 7.2v nimh (2000mAH), with 55t motor my battery last about 1 hour. and with 20t motor the battery only last less than 30 minutes.
01-19-2010, 07:35 PM | #6 |
Thanx guys for the info. I definitely want to get 27t just to drive around the street and lawn. I like to use 55t for crawling rocks. I don't mind switching motors. How about the small and large pinion gears? How about the Heavy Duty Bevel Gears with low speed and high speed? Will these make big differences in speed? |
01-23-2010, 08:35 PM | #7 |
Newbie Join Date: Dec 2009 Location: Nature Coast of Florida
what about say 20 mph? what motor then?
02-06-2010, 03:51 PM | #8 |
I'll stick with 27t.
