02-04-2010, 05:50 AM | #1 |
| Ckrc bta?
Whats better the CKRC BTA or the Axial BTA?
02-04-2010, 06:49 AM | #2 |
Pebble Pounder Join Date: Jan 2009 Location: Helsinki, Finland
Axial's one is better.
02-04-2010, 07:41 AM | #3 |
Rock Stacker Join Date: Feb 2009 Location: Oslo, Norway
Either of them let you use 4-link in the front. LD Products BTA (RPPHobby) is made for 4-link. I would recommend this and the CKRC high-steer knuckles.
02-04-2010, 08:02 AM | #4 |
I'd go Axial all the way, though the LD racing is pretty good and not terribly expensive.
02-04-2010, 09:50 AM | #5 |
I am shopping these myself right now. What re the pro's and cons to each? I see many say "choose Axial" but why the Axial one over the others? They all seem 4 link compatible. the pics on the CKRC site show it in a 4 link setup, the LD one comes with a 4 link plate,and the axial one is well... Axial.. |
02-04-2010, 09:57 AM | #6 |
I have run the CKRC before. Bought several of them for different rigs. Work good but gets pricey when compared to the LD racing setup. I bought the LD Racing setup last month. I really like it alot. Has everything you need for like $18. Plus, it small time vendor. |
02-04-2010, 10:08 AM | #7 |
RCC Addict Join Date: Feb 2006 Location: ccxc
I have the ckrc...no issues,...axial is waaaay pricey
02-04-2010, 10:33 AM | #8 |
Rock Crawler Join Date: Sep 2007 Location: Petaluma
there all going to do the same thing.i like the LD BTA kit from RPP Hobby,it's cheap and i like to support the local's.i just use high clearance knuckles from Axial
02-04-2010, 11:41 AM | #9 |
If I'm not wrong, the Axial high-steer knuckles only fits the Axial BTA "drag bar"? My LD setup has the right length for the stock knuckles as well (even though stock knuckles stop in the lower shock mount...).
02-04-2010, 11:46 AM | #10 |
Where is the cheapest place to get the Axial BTA?
02-04-2010, 12:27 PM | #11 |
The Axial if it ever gets released will be the best. I've ran the CKRC for a year, they say it won't work with 4link but I never got it to clear a three link and found it works great with 4link. If you get the CKRC or the LDRP order a set of extra knuckle (kingpin) bushings also, cut the bushings just longer than the link bar is thick and drill the bar to fit the bushing. That will allow you to tighten everything up and keep the screws from cutting into the link causing slop, Axial fixed that issue with there kit. I'll soon be making my own link bar cause none of the kits will clear my shocks to allow the steering I'll be getting from Super 300's.
02-05-2010, 01:30 AM | #12 |
Quarry Creeper Join Date: Aug 2009 Location: Golden, CRAWLERADO
i am running the LD BTA kit with the axial high clearance knuckes. i like the fact that its set up for a 4 link. might buy the axial kit whenever it is released just to have the spare parts.
02-05-2010, 01:40 AM | #13 |
02-05-2010, 08:31 AM | #14 |
I ended up ordering the CKRC with high steer knuckles last night after I snapped a stocker in half. i will know for myself next week how things go |
02-06-2010, 12:40 AM | #15 |
Quarry Creeper Join Date: Nov 2009 Location: East Bay
I am running the Axial BTA on my kids AX10 with front four link...
02-06-2010, 01:25 AM | #16 |
02-16-2010, 04:28 PM | #17 | |
RCC Addict Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
02-16-2010, 05:18 PM | #18 |
Pebble Pounder Join Date: Dec 2009 Location: In the Bluegrass
Is Axial coming out with a new bta that is set up for 4 link? I just installed the new Axial bta and it is not set up for 4 link. Steering is great but not set up for 4 link.
02-16-2010, 05:22 PM | #19 |
I don't use any washers, the bushings are the one's that go in the knuckles where they screw onto the C's. AX30450 Flange pipe 3 x 4.5 x 5.5, i cut the 5.5mm (length) just longer than the link bar is thick, I drilled the link bar to a size that I had to push the bushings in with a vise (after a few hours running they spin free in the bar but haven't got sloppy). You could put a washer between the bar and knuckle but I haven't found it needed. I put the screw up through the knuckle tight with loc-tite, then install the plate with the flange up. On the steering link side I put the rod end on then a nylock nut almost tight, on the other side just the nylock almost tight. I don't have any clear pics but will try to take some. |
02-16-2010, 05:25 PM | #20 |
| You just need to swap the servo plate, the LDRP or CKRC viper plate are direct swaps, the STRC plate works with a little cutting. Or make your own plate by tracing the Axial one and adding a tab in the center for the link mounts, here's a pic of the CKRC plate that shows where the link's need to mount.
