02-08-2010, 07:44 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: roy
| shocks coming unscrewed
Ok, I just got an used axial and when it articulates hard in the back the shocks come undone. I' ve had to rescrew them back together but now I don't have any oil left. Is there a common fix for this?
02-08-2010, 08:07 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
Sounds like the caps or the shock body is striped. Losi 4" crawler shocks are a good upgrade and a direct bolt on.
02-08-2010, 08:22 PM | #3 |
Pebble Pounder Join Date: Dec 2009 Location: oregon
i have axial 72-103mm the work great
02-08-2010, 08:39 PM | #4 |
Newbie Join Date: Oct 2009 Location: Grande Prairie
| Basically it is a problem and the common fix is to replace them, traxxas big bores work as well and even better with the shock cap mod.
02-12-2010, 02:08 PM | #5 |
Newbie Join Date: Jul 2009 Location: Sweden
The traxxas big bores? Can i use the Slash ones? Fronts or rear?
02-12-2010, 02:22 PM | #6 |
Or maybe the t-maxx?
02-12-2010, 02:48 PM | #7 |
RCC Addict Join Date: Jun 2008 Location: Fresno
tmaxx ones would be a direct replacement but i'd go w/ the slash rears. and an aftermarket chassis. |
02-12-2010, 02:52 PM | #8 |
Pebble Pounder Join Date: Sep 2008 Location: cny
I've also heard that you shouldn't fill them up all the way leave between a 1/16th to an 1/8 of an inch from the top.mine popped off in a hard binding spot and i believe this is the reason for it refilled them and haven't had the problem since. |
02-12-2010, 02:52 PM | #9 |
Thanx. I will go T-maxx, full droop, edge chassis.
