02-13-2010, 07:36 AM | #1 |
RCC Addict Join Date: Feb 2006 Location: ccxc
| Front C screws
The 2 screws that hold the c's on are starting to strip on both sides. They back out alot. Is there a fix for this short of a new axle housing?
02-13-2010, 07:44 AM | #2 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Not really, other than trying some CA glue. not much material there to fix threads. A 6-32 screw might work though, you could try it and see.
02-13-2010, 07:51 AM | #3 |
Quarry Creeper Join Date: Jun 2009 Location: Fredericksburg
You could assemble them w/ locktite red. They should hold up fine. But you better order housings, because when you take them off again they'll be no threads left. |
02-13-2010, 08:49 AM | #4 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
Before mine started loosening I managed to break the ends of the housings completely. So I epoxied some aluminium tubing inside there, and drilled and tapped the holes for the 'C's. Now those screws go into metal and can be fully tightened without risk of stripping the plastic. It makes the whole axle stronger and more rigid too. I know you need pics, but I don;t have any, sorry. Use your minds eye! Cheers. |
02-13-2010, 05:08 PM | #5 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
If they're alumimun c's, loctite on threads nearest to screw head. If not, new axle housings for $8 on ebay
02-13-2010, 08:31 PM | #6 |
Rock Crawler Join Date: May 2009 Location: Medford, Oregon
