02-14-2010, 05:25 PM | #1 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
| Rebuild DNA or buy a VP/hurtz dig
Option to either buy a rebuild kit from RPP, buy a new one for about the same price, or save for a VP/Hurtz. I figure that parts for the DNA are going to dry up after a while, and I don't want to be left up in the air. Is there any other option I should be looking at? |
02-14-2010, 06:32 PM | #2 |
RCC Addict Join Date: Jun 2005 Location: Prosser
While the steel internal kit would last longer in the dna than the aluminum internals, I would save up for a VP dig. I own two, and they are great! Awesome quality, low cg mount for servo, and no need for a strong servo to shift...
02-14-2010, 06:57 PM | #3 |
Pebble Pounder Join Date: Dec 2009 Location: here
| See Solomon
Solomon has brand new DNA's $35 shipped....Can't go wrong there. http://www.rccrawler.com/forum/showthread.php?t=204553 Got one and it works great. |
02-15-2010, 02:54 PM | #4 |
Rock Stacker Join Date: Jul 2006 Location: Seattle
VP dig is like butter with just a mini servo, save for one of those.
02-15-2010, 03:04 PM | #5 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
ive done both just rebuild my dna last weekend and my other 2.2 has the vp i like them both alot
02-15-2010, 03:27 PM | #6 | |
Exactly, they parts will "eventually" run out. So since you already have the DNA just buy the steel replacement pieces. it'll be cheaper, and you already know how it should work. On top of that, by the time you do run out of replacement parts, the VP should be cheaper, or will be outdated and replaced with the next big thing. | |
02-15-2010, 05:30 PM | #7 | |
Sound advice. I'm gonna go that route. | |
02-16-2010, 04:48 AM | #8 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
I switched from DNA to VP in both my comp rigs. 100% go with VP |
02-16-2010, 05:41 AM | #9 |
for future ref when I can get the VF dig, will it fit the Hot Racing alum diff? VF didn't know for sure, I already asked him.
02-16-2010, 12:09 PM | #10 |
02-16-2010, 12:13 PM | #11 |
02-16-2010, 12:57 PM | #12 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Most of the differences in the alum. housing will be near the bottom, where the tranny bolts to the skid. This area will probably be square-looking, whereas the stock housing is rounded where the screws go up into it, so some filing will have to be done to mate them up. Also you'll need to check how thick the case is on the flat sufaces of the housing, but that usually is pretty close. Another area to check would be the bearing bosses on the back of the tranny, those could be different also, and might need fitting. Could end up being a lot of work. The easiest thing to do would be to get a VP aluminium case, as it matches the stock case perfectly, if you want an aluminium case. These two pics show the areas in question, you can see what I had to change to get a VP dig to fit an S3R case: Last edited by gunnar; 02-16-2010 at 01:11 PM. |
