02-26-2010, 12:41 AM | #1 |
Newbie Join Date: Nov 2009 Location: Trabuco Canyon
| Rover Tire Question
I have a pretty much stock set up. I want to get some rovers but im worried there gonna rub. Can i run rovers on the stock rims? Will they rub on my links or any other components? Are they really as good as everyone says? Im looking for a good all around tire, not just for rocks
02-26-2010, 01:10 AM | #2 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
yes you can run em on stock rims, yes they probly will rub just set your epa's and trim the body,yes they really as good as everyone says...get white dot rovers i have the new ex pink dots, i was more impressed with my whites. in vest in a good set of foams nova 5.5 or proline stage2's
02-26-2010, 07:17 AM | #3 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
X 2 ^^ Putting white dot Rovers on a stock-ish AX-10 is the biggest single upgrade you can do, IMHO. They fit stock rims and work nicely with stock Axial foams. They are a little bigger so they'll hit bodywork, just trim it. Generally you can still have full steering with the stock shock and link locations. And they work well even on slimy rocks, crumbley hard packed dirt and wet, smooth river stones. Only catch is:- you'll start breaking other things due to the extra traction! Cheers. |
02-26-2010, 02:46 PM | #4 |
Newbie Join Date: Oct 2009 Location: chickamauga
I put them on my ax10 and absolutely love em. I have the links and shocks in the factory position and have no problems. They want to rub the link a little while sidehilling in full lock, but not enough to hinder performance.
02-26-2010, 03:51 PM | #5 |
02-27-2010, 08:11 AM | #6 |
Pebble Pounder Join Date: Jan 2010 Location: Murrieta
i have seen these in action love them so ordered me a set for mine keep update on the working performance
02-27-2010, 09:03 AM | #7 |
Pebble Pounder Join Date: Dec 2009 Location: here
Definitely the best 20 I've spent so far. Be sure to weight and vent the rims and you're good to go. I have whites and put 8 oz in the fronts and 4 in the rears. Good luck! |
02-27-2010, 08:08 PM | #8 |
Newbie Join Date: Nov 2009 Location: Palisade
I changed over to the Rovers (white dot) and tried both memory foam and the stock gray foams on stock rims. For me the gray foam worked best. Definitely an improvement. Also added the Wheel Pig weight set up at the same time. Still playing with the weights.
02-27-2010, 11:03 PM | #9 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Rovers fit on any rim that will hold tires Sure some work better than others but overall they fit good. I am amazed that you can cram them onto those psycho narrow rims Man those tires have to be one major improvement on the AX10. I got mine used and never got it with the rock lizards but it came with some pretty crappy tires and the rovers made it planted Just a word of advice, take your time installing them since the bead is pretty flexable, it can be prone to going in slightly crooked and that is mad frustrating |
02-27-2010, 11:15 PM | #10 |
Quarry Creeper Join Date: Feb 2008 Location: Citrus Heights
Mount them up and don't worry about them rubbing on anything. it wont hurt a thing. |
