03-02-2010, 01:30 PM | #1 |
Pebble Pounder Join Date: Oct 2005 Location: Rocklin / Ukiah, CA
| Steering CVD Problem. Help! *video*
Ok, So I installed Axial aluminum knuckles and c-hubs recently. Shortly after a few weeks later I noticed the steering pulsating like you see in the video. Last night I reinstalled the stock plastic parts and still the same problem. I never changed the steering endpoints when I went to the aluminum. I still also have the stock dogbones and axle stubs. I've tried everything short of limiting the turning endpoints because I should not have to because it was working this way before. Any advice? |
03-02-2010, 01:40 PM | #2 |
Pebble Pounder Join Date: Jun 2009 Location: Finland
Try to loose your hexs.
03-02-2010, 02:23 PM | #3 |
Hoof Hearted? Join Date: Nov 2009 Location: Chattanooga
You are now being limited by your drive cups. If you watch closely, you can see the pulsing happens when the slot in the cup passes the tightest point. You can grind the end of the cups a little to help. Once you get the tires back on, it may not turn that far anyway. Your tires willl probably hit the links or shocks.
03-02-2010, 03:30 PM | #4 |
Does it look like I need to upgrade to the Axial comp CVDs? Would those fix the problem?
03-02-2010, 04:17 PM | #5 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
i can now say i would never recommend axial cvd's to another person. ive broken the pins in mine every other comp night. and the problem will still be there. just a little bit more steering before it does it. if you want smooth and strong get the super 300 cvd's. or possible the felsonfest cvd's, i have no experience withe the felsonfest but Ive read they are great cvd's |
03-02-2010, 05:22 PM | #6 |
Pebble Pounder Join Date: Nov 2009 Location: Bunbury, WA
Try the gunar pins if you break yours all the time. My axials have been good so far. I cant believe the price of the super 300's. There just a bit thicker.... yes they are bullet proof but they could price them at like $60 (double the axials) not $150. Theres no way it cost them more than $20 to make a set....... As for the pulsing. Its definately those cups. i had the same problem which went away when i put the axial CVD's in. |
03-02-2010, 05:28 PM | #7 | |
i was basically making my own gunnar pins. still shattering those. there is alot more stress on the pins when you max out the cvd's steering capacity. if you axials aren't notchy then your steering isn't turning far enough. another thread. same problem, with axial cvds. axial bta kit help VIDEO the 300's turn a hair further than the axials but are much much smoother at full lock. and are STRONG | |
03-02-2010, 05:46 PM | #8 |
My EPAs are set to stop just as the knuckles touch the axle housing so i couldnt get more steering if i wanted to. I havent had a problem yet. If they start to break i'll have a crack at making my own, otherwise i guess i'll have to fork out for the 300's. I do know that once you buy 300's you never have to worry about them again. Just have some other stuff to buy still before i spend that much on axles. |
03-02-2010, 06:02 PM | #9 |
Other than the obvious strength. Is everyone sure that you get any more steering out of them over the axial cvd? Are they not the same design, just on steroids? Also I agree on the possible overprice. When you think about how your only getting a couple of steel rods. $150.00 is a lot of money for 6 inches of steel. I could maybe justify $99.00. But $150.00 is a bit much. Just my 2 cents. |
03-02-2010, 06:53 PM | #10 |
Overpriced? Don't forget they come with a zero slop locker also. Since October I've bought one complete set of Axial CVD's, a set of replacement cups, a rebuild kit and a set of shafts, two four packs of MIP CVD's, a pack of cups, two rebuild kits and 3 sets of shafts, also busted stock dogbones and an untold number of pins. 300's are a bargin, they're gonna save me cash. $20 for that much 300m cro-moly, LOL, not to even mention the locker, bearings and machine time. Anyways, yes I'm positive they steer farther and much smoother, plus take a ton of slop out of the front end. |
03-02-2010, 08:30 PM | #11 |
Oh, i didnt realise they came with bearings and the locker. They are not in the pic on the TCS site, just in the description. They are the price they are since they're the only alternative to all the brands that break. And i'm sure i'll probably get a set one day when i get sick of breaking CVD's too. But the material is not expensive.
03-02-2010, 09:29 PM | #12 |
I did realize it included a locker either. Hmm, $150.00 is sounding alittle better all of a sudden. Anyone have pics of the locker? Pictures of everything you get maybe? Thanks for clearing it up a little. |
03-02-2010, 09:31 PM | #13 |
cvd's locker outer axle bearings outer knuckle bearings |
03-02-2010, 10:11 PM | #14 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
what setup do you have in there?
03-02-2010, 10:16 PM | #15 |
Thats the 300's. I thought you ran the HD gear romulus? That looks like the stock gearset, the HD's are black. |
03-02-2010, 10:23 PM | #16 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
03-02-2010, 10:46 PM | #17 |
Quarry Creeper Join Date: Jun 2008 Location: Honolulu
03-03-2010, 04:55 AM | #18 |
03-03-2010, 12:18 PM | #19 |
300's hmm i might have to bite the bullet and invest in a set of these, how do you like the underdrive front and rear, i was think about doing it just rear and stock front?
03-03-2010, 12:58 PM | #20 |
| That explains alot then, and after looking at the different gearsets I got laying around I can tell thier UD's. The UD/OD gearsets are gray and not nearly as hard as the stock ratio HD set thats black. Hence why you had sucess with a dremel and all I could do was eat the teeth off all my dremel bits.
