03-18-2010, 10:44 AM | #1 |
Rock Stacker Join Date: Mar 2008 Location: Temecula
| Solved my Torque Twist Problem
Well i reduced it by, i would say 80%. I switched to a 4 link setup with custom lengths. The stock links totally sucked. I switched to the stage 2 setup which helped but still sucked. Switched to custom 4 link and it works great now. Here are some pics of my setup. BEFORE SETUP AFTER SETUP |
03-18-2010, 11:06 AM | #2 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Looks like your rig is going backwards in the first cardboard pic, just switch links around/4 link?
03-18-2010, 11:15 AM | #3 |
I tested it forwards and backwards with the stage2 setup, and it was the same amount of twist. I forgot to take pictures before i switched to my 4 link. Sorry, but as you can see, it did wonders. Tested it out on the rocks and i am happy with the improvement.
03-18-2010, 09:08 PM | #4 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Make sure to "clock" your C's so the front links don't grind on the rocks all day I did my own version of the CKRC stage 2 and it was an "improvement" but your right, it isn't the end all for issues with the stock chassis You may want to try drilling 2 more outer holes on the battery plate to allow for more testing positions |
03-19-2010, 09:35 AM | #5 |
Do not know the term "Clock your C's". Also the two outer holes that you are talking about, is that on the servo plate? I kept the stage2 on the front, i am thinking of doing the 4 link on the front also, what do you think? |
03-19-2010, 10:51 AM | #6 |
After spending some time here in the forum, i think i know what your talking about. I need to twist steering knuckles, this will adjust my caster. I know you would want positive caster, but how much. Right now i am bigtime negative due to adjusting my pinion angle. What does it take to twist the steering knuckles, is it hard? |
03-19-2010, 12:12 PM | #7 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
There are clockable Cs from both Axial and HR. I use the HR onesw and seem to be holding up great after tons of abuse.
03-19-2010, 02:54 PM | #8 |
I looked at a few websites and i cannot find any adjustable hub carriers. Can someone throw some links at me?
03-19-2010, 02:59 PM | #9 |
These are the only ones i found. Are these the adjustable ones? Here's a pic Here is the website incase you want to know http://www.tcscrawlers.com/Axial-Rac...5-p-17308.html |
03-21-2010, 04:54 PM | #10 |
Newbie Join Date: Jan 2008 Location: Greeneville/Cookeville
Nice fix on the torque flex. What length links did you use? Also when flexing do you links touch?
03-22-2010, 11:20 AM | #11 |
I got the mounting points from a suspension program an aquaintance of mine had that he used on real rock crawlers. I cut them to length according to what pinion angle you want. The links do not touch. |
03-22-2010, 04:19 PM | #12 |
Thanks for the clarification. I should get mine done this week.
03-22-2010, 05:49 PM | #13 | |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
http://www.tcscrawlers.com/Hot-Racing-added-Castor-angle-C-Hubs-for-Axial-AX10-Scorpion-SCP19X01-p-17273.html And the Axial ones: http://www.tcscrawlers.com/Axial-Rac...5-p-17308.html | |
03-22-2010, 07:35 PM | #14 |
