03-18-2010, 10:56 PM | #1 |
Newbie Join Date: Mar 2010 Location: NZ
| HELP: Purchasing a SWX chassis kit
Hi, I have a stock AX10 RTR and I want upgrade to a SWX chassis. I plan to buy the SWX Chassis kit and the Axial RTR Hardware Upgrade Kit (as I want to swap the stock plastic part for aluminum). The question I have is I beleive I need some additional posts (pipes) for the steering but I am not 100% sure of the lenghts etc. I think I need: 1 x pipe 6mm x 106mm 1 x 6mm x 32mm and some real small ones for the vertical pipes that hold the battery/servo late over the axel. Could someone please confirm this or give me the correect parts I need to the front steering. Thanks |
03-19-2010, 12:37 AM | #2 |
Rock Stacker Join Date: Feb 2009 Location: Oslo, Norway
It sounds like this is what you need - but you could download the instructions for the kit or ARTR, and check the parts list
03-19-2010, 12:50 AM | #3 |
Newbie Join Date: Jan 2009 Location: townsend
The 106mm and the 32mm are right for the steering "if your using the servo tray only" STOCK ... the 32mm will not work for the battery/ servo tray combo. there too long. the ones for the servo/battery plate come with the right length ones in the kits I've seen. Just measured my spacers for the battery/servo mount there about 19mm. I bought a carbon fiber battery/servo holder off of Ebay for 9.99 "buy it now price" and it came with 2 spacers and 1 link for the servo. Last edited by BAM-BAM; 03-19-2010 at 01:21 AM. |
03-19-2010, 01:20 AM | #4 |
Thanks, would anyone know what the real small ones are in lenght that go underneath the battery/servo plate vertically. And the battery/servo plate I am purchasing does not come with any posts so would the smaller pipe be less than 32mm? Cheers and thanks. |
03-19-2010, 01:22 AM | #5 |
re read my post
03-19-2010, 09:48 AM | #6 |
Rock Stacker Join Date: Apr 2009 Location: sheilock
I just converted my scx10 int a swx all I did was bought the ax10 optional battery/servo mount and it comes with everything and the swx chassis kit and everything bolted up and yes your lookin for stock servo tray u need 6x33mm post and 6x106mm spacer or if your usin the opitional battery/servo mount u need 7x20mm post and 6x106mm spacer
