Thread: Sverref`s FF4 chassi project
Old 03-25-2010, 03:26 PM   #1
Default Sverref`s FF4 chassi project
here is my baby, just got it in the mail today and this is how far ive come today:p
the back end isnt the way it should because im missing some parts, but just had to mock it up so i copuld se how it would sit
the list of goodies that im going to use on this mofo:
Underground Crawler`s FF-4 chassis
Junfac(gmade) G-Transition droop shocks
Junfac Driveshafts
Phatty links lower links custom made.
white dot Rovers med Nova 2 stage foam
STrc Straight axle adapters with new axles
STrc alu c hub
LD racing BTA kit
Robinson racing Gears in the gearbox
Felsenfest No slop spool lockers
going for over/under gearing in the axles
VP hurtz dig incl mini servo mount
VPhigh clearance steering knuckles
VP 4link plate rear
VP Razors
Axial cvd axles
Tekin FX-R esc with 45T Pro Tekin motor
sterring servo is hitec7950 or hitec 7955tg, if anyone has any bad/good to say about these wo and wich i should choose, then feel free to post up
JConcepts Gate Crasher Crawler body
here comes some kinda pron
loooong driveshaft
flex shot need to get alittle less flex when i get the shock im going to use on this rig :p
Sverref is offline   Reply With Quote
Old 03-25-2010, 03:41 PM   #2
Lookin good. I'm running the stock Axial drive shafts on my FF4 and that rear one is stretched out about as long as it can go. I'm amazed it hasn't exploded or stripped out on me but it's been hanging in there.
I'm running a FXR a 55T motor with a 3S lipo, a 45T would probably give me just enough wheel speed to destroy something in no time at all
Do you make your own links? If so what do you use to taper the ends? They look really clean.
Phylodog is offline   Reply With Quote
Old 03-25-2010, 03:44 PM   #3
Build is looking good so far! I am running Mip C-Spline on mine. I use the shorty (dig) spline on the front and a ground down regular spline on the rear. I do have a VP dig installed which pushes the spline back a bit. They barely made the connection before I installed the dig in the rear.
Looking forward to seeing another FF-4 progress to a functional whoop ass shafty!
DickyT is offline   Reply With Quote
Old 03-25-2010, 03:46 PM   #4
looks good so far
but why is your steering linkage in the front, and not the back. it is a Bta link, right?
sheedy126 is offline   Reply With Quote
Old 03-25-2010, 03:54 PM   #5
Originally Posted by sheedy126 View Post
looks good so far
yea its a bta link and this is just first mock up, i dont have all part to build it yet:p going to go for VP dig vp High steer knuckles VP rear 4link plate Gmade Transition shocks junfac driveshafts. and VP razors(not sure on those but ill buy and try)
the links are R2J custom phatties and they made the perfect length 12.5in full droop and 12ish in full extension:p
this build will take som e time since the tax refund crap bit me in the arse and i have to pay 2333$in extra tax this year ./cry
i have FXR esc and 45T motor and im going to power it with a 3cell lipo :p
im just missing the VP, Junfac parts and steering+dig servo par to make it complete and its approx 500-600$until completion.
Old 03-25-2010, 03:56 PM   #6
hopefully mine will become half as badass as your rig Dicky, its my first scratch built anything:p
Old 03-25-2010, 08:07 PM   #7
No idea what I'm doing
Great Start Sverre, and I'm glad this made it to you! Looking forward to checking out your updates
C*H*U*D is offline   Reply With Quote
Old 03-25-2010, 08:10 PM   #8
The more of these I see in black wrinkle I wish mine was
Old 03-26-2010, 12:39 AM   #9
Congrats on the new rig Its looking good.
Are you planning on running it full droop?
TOMCAT18T is offline   Reply With Quote
Old 03-26-2010, 12:49 AM   #10
added a list of items thats going on this little sucker, i have all parts except vp and junfac:p
going for the Gtransition dampers they are almost full droop i think.
Old 03-26-2010, 08:43 AM   #11
made a mockup for the ESC mount
Old 03-26-2010, 08:53 AM   #12
R2j
SORRCA Committee Member
R2j's Avatar
Man that's turning out great Sverref!
R2j is offline   Reply With Quote
Old 03-26-2010, 09:29 AM   #13
Thanks
Old 03-29-2010, 12:43 AM   #14
heres a shitty iphone pic of the late night work i did lastnigth:p
better pics comes when i get home from Work
i think it sits pretty good there, just need a little more Ground clearance 10mm or so i think
Old 04-02-2010, 10:11 AM   #15
Default Wheels
What wheels are you running? I like em.
RickM is offline   Reply With Quote
Old 04-06-2010, 04:55 AM   #16
these wheels http://www.rc4wdstore.com/2/product_...roducts_id=300
but i think they are going to get replaced they sit to tight on my steering knuckles:(
i wonder one thing, should i go for the 1/8 scale G transition shocks or the 1/10 ? only difference is the spring tension rate, pls help me
Old 04-06-2010, 07:16 AM   #17
Go with 1/10 g transitions. you rig will not weigh enough for the 1/8 and will run very stiff.
Old 04-06-2010, 07:24 AM   #18
ty
Old 04-06-2010, 07:33 AM   #19
Nice set up. Looks great.
Kanine38 is offline   Reply With Quote
Old 04-06-2010, 09:07 AM   #20
Hi Sverref! Are you coming to the big RC4WD Nordics with this?
ErÄjOrMa is offline   Reply With Quote
