03-28-2010, 07:46 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: Gill, Taxachusetts
| Axial mentor needed
There's just too much stuff to learn! I need a friggin' mentor who is wise in the ways of the Axial AX10. Stuff that need to be discussed: 1) General set up 2) Shock issues 3) Upgrades that will make a difference. This is a non-revenue producing adventure so think it through. Applications will be accepted through April 5th. Thanks in advance, Kanine |
03-28-2010, 07:50 PM | #2 |
Pebble Pounder Join Date: Jan 2009 Location: At the workbench
Aww he11, I'll bite. Sign me up. |
03-28-2010, 07:52 PM | #3 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Why not let RCC be your mentor? There are thousands of tips, builds, info,-right here |
03-28-2010, 08:02 PM | #4 |
03-28-2010, 08:08 PM | #5 |
^^^^^^^^^^^^^^^ Very good points guys, but I want my very own axial virgin. |
03-28-2010, 08:30 PM | #6 |
Rock Crawler Join Date: Jan 2010 Location: Arvada
03-28-2010, 08:38 PM | #7 |
I figure high post count just means more time typing than driving. |
03-28-2010, 09:32 PM | #8 |
RCC Addict Join Date: Jul 2009 Location: AT THE DRAGON'S LAIR
03-29-2010, 05:17 AM | #9 |
Well, I do drive. I drive on my basement course and if you go to you tube and search Kanine01354 you can see my latest adventure this past Sat. I do have a lot of posts. I'm trying to get on the fast track to knowing this stuff and being able to help those who are not wise in the ways of the Axial. I have a 2s Lipo coming in today with a new 6 cell NiMh in a brick format to be mounted in my custom front servo/battery mount. I also have my revo rod ends coming in to beef up my lower links. My front shocks are another matter though. I'm running Traxxas Emaxx with LMC soft springs. Did I see that there was a mod done to the lower cap to help the springs seat? My front end is pretty tight. I don't want 85 degrees of articulation but my ride will roll over before the shocks give an inch. I'll post pictures later. You can see a vid in my other post " Stick packs suck". |
03-29-2010, 06:08 AM | #10 |
There is a mod somewhere in the bully section but I can't find it. IIRC, he just drilled a hole in the cup and tied the spring to it with a piece of wire. If I can find the link I'll edit it into this post. |
03-29-2010, 06:26 AM | #11 |
03-29-2010, 06:29 AM | #12 |
High post count? Pfffff.
03-29-2010, 07:34 AM | #13 |
03-29-2010, 07:38 AM | #14 |
03-29-2010, 12:19 PM | #15 |
Newbie Join Date: Mar 2010 Location: Salem
Well Since We Are On The Topic Of Axial Mentors I Could Always Use A Axial Mentor And Hey Im A True Axial Virgin Lol. I Just Purchased The RTC Scorpion Two Weeks Ago. All Ive Done Is Bought Rear Bent Links And Chisel Tires Which Ive Yet To Put On Lol
03-29-2010, 12:37 PM | #16 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
| Take the Chisel's back and get your self some white dot Rovers, They will work much better, but either tire will be better then the stock ones, Also upgrade to a Hi-torque steering servo and a Castle BEC so you have enough voltage to run it. |
03-29-2010, 01:16 PM | #17 |
03-29-2010, 01:23 PM | #18 | |
It's a lot more fun anyways. | |
03-29-2010, 01:24 PM | #19 | |
See???? I NEED a MENTOR!!! | |
03-29-2010, 02:17 PM | #20 | |
| 11,000 post of chit chat. Quote:
Voltage is voltage whether it comes from a potato, or a battery. | |
