04-08-2010, 06:15 PM | #1 |
Rock Crawler Join Date: May 2009 Location: Medford, Oregon
| Home brew AX-10, need dig mount help.
Spent some time at my work bench making my own chassis, skid, and links. I want to run a DNA dig but am having some trouble figuring out how to mount the servo for it. I've got two choices for dig servo size, mini of full size. Take a look at this and post up any ideas you might have, due to me being stuck on how to mount a dig servo. |
04-08-2010, 06:40 PM | #2 |
RCC Addict Join Date: Jan 2010 Location: Dallas
| I kindof had the same problem with my Truck
I had the same problem mounting my dna dig in my FF4. I wound up using the same servo mount from DNA. I basically flipped the servo around and mounted it by only one side of the tabs. It is not ideal but it is working. I intend to take a flat aluminum plate and mount servo mounts to it. Enclosed is my thread and if you search my pics you can get an idea of how I made this work. My new concept to give it more strength actually involves mounting the servo the exact same way but with a plate underneath it to give it support. RickM's FF-4 build too. Nice work on your home brew by the way. You don't strike me as a shade tree kindof builder!! |
04-08-2010, 07:02 PM | #3 |
When you get laid off from work, time at the bench is cheap. I made this rig from spare parts and 1/8" aluminum plate I had here at the house. Thanks for the ideas. |
04-08-2010, 07:18 PM | #4 |
Quarry Creeper Join Date: Oct 2008 Location: Valley Village
I had to drill new holes in the servo mount to move it over so it wouldn't hit the chassis... I know it's old school I drilled em on the wrong side, now servo sits a little back now too. I like your chassis! |
04-08-2010, 07:25 PM | #5 |
I like how you got yours to work, I may go that route, but I would like to keep the servo low.
04-08-2010, 08:36 PM | #6 |
Rock Crawler Join Date: Mar 2008 Location: ...in your meter box...
This is what I did on a previous build. I did have the original servo mount, but had to relocate it. I just cut a piece from the stock battery mount plate, used the original mount to mark for drilling, twisted it a bit and slapped it in. It worked flawlessly. I am pretty sure that with your machining skills you wont have a problem coming up with a solution. Just make sure that the dig linkage engages as straight as possible wherever you put it. I also think you might have trouble with that lower chassis brace hitting your dig linkage. Is it necessary for chassis strength? If not I would probably lose it altogether. Oh...Killer looking rig by the way! I really like those white links. - |
04-08-2010, 08:54 PM | #7 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
if you can afford to lose that brace in between your rear uppers i think you have room to make something similar to what i came up with for my VP |
04-08-2010, 09:27 PM | #8 |
I sorta need to keep both cross braces to keep the chassis from flexing. I am considering making something similar to RcBro's low CG dig mount to incorporate the mount for the servo into the cross brace. As for the machining, I did all this with a cordless drill, coping saw, dremel, files............and elbow grease. Last edited by RIG_RIDER; 04-09-2010 at 12:17 AM. |
04-09-2010, 12:17 AM | #9 |
