04-16-2010, 04:19 PM | #1 |
Rock Stacker Join Date: Nov 2009 Location: NM
| Looking for some part #'s...
There are a few Axial parts that I am looking for but can't seem to find: Stock Axial Servo Mounts (the pair of plastic mounts, not the plate) Springs for Axial Comp/RTC Shocks Axial RTC Shock Parts If you know the Axial part numbers or a link to a store that has these parts for sale (preferably Tower Hobbies) I would appreciate a reply. Thanks |
04-16-2010, 06:03 PM | #2 |
Try either RPP... http://www.rpphobby.com/category_s/28.htm or Brians Hobbyland... http://shop.brianshobbyland.net/Axial_c4.htm If you can't find what you need, email either of them and they will hook you up. |
04-16-2010, 06:18 PM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: Tehachapi, Ca
the RTC springs: AX30218 -super soft AX30219 -soft AX30220 -medium AX30221 -medium firm AX30222 -super firm the RTC shock parts: AX80036 -shock body AX80035 -shock cap AX30112 -shock diaphragm AX30113 -rubber bump stop AXA1041 -nylon locknut AXA1069 -washer AXA1202 -O-ring AXA1184 -O-ring AX30155 -shock shaft AX80035 -shock parts tree the servo mounting kit: AX80007 -servo mounting kit i hope this helps |
04-16-2010, 07:47 PM | #4 |
Losi springs work on those shocks to, I run gold Losi's in the front with red (super soft) Axial's in the rear. Your stock springs should be three reds and a blue.
04-16-2010, 10:21 PM | #5 | |
