Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Frame Spacer Width?
Old 05-28-2010, 11:45 PM   #1
Rock nocker over!
RksPlz's Avatar
Default Frame Spacer Width?
How long is the stock frame spacer for the ax10?
RksPlz is offline   Reply With Quote
Old 05-29-2010, 12:14 AM   #2
The brace between the shocks is 55mm, the brace that goes around the shock and holds the batt tray or the skidplate is 80mm. Not sure which width you needed.
indiana mudcat is offline   Reply With Quote
Old 05-29-2010, 12:19 AM   #3
Rock nocker over!
RksPlz's Avatar
Yes up by the upper shock mount,I guess I should have been more specific. I am not going to use a battery tray, just use a post for support. Thank you.
